clunking noise in the front end
i have a 04 evo and when i go over bumps there is a clunking noise in the right front i was wondering if any body has had this problem
See here:
https://www.evolutionm.net/forums/ev...n-related.html
Mine doesn't clunk anymore. I don't know if it stopped after I replaced the front swaybar. If that's the case it could still mean a lot of things.
Here is something to check, especially if you've ever had your suspension apart. Check to make sure your center strut bolts under the rubber dust caps are snug! My car and my friends car were both making a clunking noise going over bumps and it turns out on each of our cars that bolt came loose and was allowing the shock rod to flop around in the mount.
https://www.evolutionm.net/forums/ev...cs-thread.html
Here's the thread take a look through there
RevMoto
16
Nov 6, 2011 08:31 PM
sktng22
13
May 22, 2010 08:20 AM
