Ceramic pads squealing?
My OEM pads finally wore out so I bought Hawk HP plus pads and they squealed really loud and I could not stand it on the street. I searched for a different pad and picked up some Duralast Gold ceramic pads and I still have a loud squeal everytime I stop. Just wondering if the problem could be with the rotors?
I dont mind the squealing sometimes, but its annoying when it does it all the time. I will try the sandpaper trick this weekend and try to save some life on the rotors. Thanks again.
I just went from DS2500s to these pads (needed some RIGHT THEN). I took a wire wheel to them, but have an experienced hand for the sort. What Smike suggests would be the way to go for Average Joe. Just keep it REAL even, and know it will take a couple hundred miles to completely quiet down. I don't believe in "turning" rotors, I replace them first, but that's another topic/sticky.
Once you remove the old compound off the rotors, and bed them, give them an extra few hundred miles to completely bed in, your gold. Only time I get squeal now is when backing up, or after a rain with rust on the rotors. Even that is intermittent.
All in all, they are an ok pad for a daily driver if you are not a maniac (I am... miss my DS2500s). Lack of dust is nice, and at sane speeds they work well enough. Wish I'd had some Magic pads from Girodisc handy at the time though. Bet they would be a little better for more spirited driving.
Pardon the mini review... hope the info helps the OP and others though.
Also, what Kracka says is also true... if they are that worn, you need to get them mic'd to make sure they have enough meat left to safely use! Mine had a little lip, but that quickly beds in if it's not too radical to use.
4g63xawd
62
Jan 6, 2016 03:25 AM
Go_Lancer_Go
Apr 5, 2009 11:46 AM
JDM_EVOVIII
41
Nov 14, 2005 08:56 AM
HwangTKD
Aug 5, 2003 08:21 AM
