WTF! Clunkity clunk
Old Jan 13, 2010, 03:09 PM
EriCS's Avatar
WTF! Clunkity clunk
If there is anything that I can't stand its when my suspension clunks. I have had this clunk coming from the right rear side of my car where the struts are located. I recently just developed a clunk from the right front as well. It occurs only on slight bumps for both of them. I just looked at the front control arm and checked for play and it seems solid. I even packed it with grease and did the same to the trailer arm bushing as well. The car has Robispe KW's with the front roll center kit and rear trailer arm bushings. Can someone help me diagnose and isolate the problem? How and where else to look? As far as the end links are concerned the right rear link seems to twist easier than the left. Could this be a sign of a worn link? These are fairly new with only about 20/k miles on them and the car isn't tracked or anything... The front mostly occurs when I first initiate braking and accelerating but sometimes over small bumps at slower speeds. The rear is just over bumps at at slower speed as well.
Old Jan 13, 2010, 05:18 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Please do not bump more than once per 24 hours.
Coilovers tend to make more noise. Can you feel it in the car when it clunks? Do you have camber plates? Have you called Robi?
Old Jan 14, 2010, 12:01 PM
Appauldd's Avatar
Clunking is normal if you have after market end links. They will start to rattle and clunk as they wear out.
I have yet to find a set of end likes that can last through a winter other than the stock one.
dustin11
Dec 23, 2014 09:01 AM
Shadowpriest
20
Feb 16, 2013 11:33 PM
patrickhvr
Jan 11, 2013 01:55 AM
Nasty Evolution
31
Jul 9, 2010 01:21 PM
laopadak
Sep 14, 2009 11:48 AM
Quick Reply: WTF! Clunkity clunk
