Front Drivers Side 1/2" Lower Than Passenger Side
So I bought this car from a member on here about a month and a half ago. The previous owner tanked a curb with the car and numerous suspension components were replaced. Since I've had the car the drivers side tire rubs really bad on the inside of the fender/side skirt while the wheel is turned left (mainly pulling in/out of parking spaces and going around turn-a-rounds). Previous owner said it did it when he had the car as well but said it was only with the steering wheel cranked left. Passenger side doesn't rub. Put the car on my friends lift and there was less gap around the entire drivers side tire between the fender compared to the passenger side.
When the car is on the ground the driver side is 1/2" lower than the passenger side. I measured from the top of the fender to the ground from the bottom of the head light to the ground, pretty much every way you could measure drivers side was a half inch lower.
So the motor/trans is out of the car right now and its on jack stands, no wheels on it, jack stands are on the sub frame where the LCA's bolt in, drivers side is exactly a half inch higher than the passenger side (measured from the top of the fender and from bottom of the head light to the ground). I put a level between the LCA mounting points on the sub frame in the engine bay and its level, put a level on the core support and its level as well . The car doesn't look to be sitting level though looking at it from the front.
None of the mounting points on the frame are buckled/bent the whole under side of the car is fine as well. I pulled the shocks/springs and the drivers side assembly is a tad shorter (car has eibach springs). Neither of the front LCA's were replaced, they don't look bent at all. I'm pretty much baffled as to why the car has this problem, I'm mainly trying to solve the problem with the tire rubbing on the driver side, tires are 255/45/17 on 17x9 Enkie RPF-1's. Previous owner said the car was put on a frame rack and the frame wasn't bent. Any help is appreciated!
Ughh I was hoping no one replied with that. Could the frame really be tweaked a half inch and there not be any noticable damage on the frame rail? I haven't dropped the sub frame/steering rack, thats next on my list, I guess its possible that is bent some how.
Well the big issue is that the car is still uneven when its on jack stands with the suspension out of the car. I'm going to try a set of shocks that didn't meet a curb and see if that solves the shock/spring assembly on the drivers side. Im also going to pull the sub frame and measure it in more detail. If I still find issues I guess I'll take it to a frame shop. I'm going to be irrate if the frame is bent..as the prior owner said it wasn't....all this on top of the motor sending the #2 rod through the block 2 weeks ago...this thing is becomming more of a headache than my DSM I've had for 7 years
I actually picked the car up from the shop that did the work when I bought it. I'll take some more things off and see what I can find, it'd be a pain to take the car to a shop right now as the motor and trans is out so I'd have to have it towed.
So I put the passenger side shock/spring on the drivers side and vice versa...car sits perfectly even now . Both frame rails and shock towers are exactly the same distance from the ground. The driver side tire is still about a 1/4" closer to the fender/side skirt on the driver side...which I'd assume is why the tire rubs the inside of the wheel well. As of right now I'm going to wait til I get the new 2.1l and trans back in the car and I'll probably end up taking it somewhere to have it gone over with a fine tooth comb.
tribe
Aug 28, 2007 03:37 AM
