Tire / Wheel Fitment Questions
Old Apr 11, 2011, 01:12 PM
  #1741
CrackWoo's Avatar
hey guys,
i want to purchase the following rims for my 2006 Evo IX SE...
Volk RE - 30
Bronze
5 x 114.3 bolt pattern
18 x 9.0"
+50mm Offset
but i'm a bit of a newbie and not sure if the +50mm offset will be an issue with clearance on both calipers and/or suspension. can you guys help me figure out if i will require spacers or not? i'm planning on purchasing them this weekend if they do fit.
thanks in advance!
Old Apr 11, 2011, 01:30 PM
  #1742
chu
chu's Avatar
+50 wont work friend. stay in thmid 20s to mid 30s
Old May 17, 2011, 08:37 PM
  #1743
Twism10's Avatar
Just looking at some rims they are 17x7.5 with +48 offset. Does anyone know if that's too much offset? Please let me know
Old May 17, 2011, 09:15 PM
  #1744
killerpenguin21's Avatar
its 16mm closer to the suspension, but the wheel is an inch narrower than stock...i dunno why you would want to do that at all.
Old May 18, 2011, 12:34 AM
  #1745
Twism10's Avatar
I have the bbs wheels so I believe they are 17x8 no? I'm getting a really good deal on these rims soo.....
Old May 18, 2011, 11:51 AM
  #1746
jbrown's Avatar
No good for an Evo without spacers. It's actually just 4mm closer to the suspension, but it will be sunk in 16mm more than stock and will make your car look like a base model Camry or Mirage. Plus the 7.5" width is weak.
Stockers are 17x8 +38mm FYI.
I highly recommend you pass on this and tell him to sell them to someone with a Honda.
Old May 19, 2011, 09:46 PM
  #1747
aaparker's Avatar
FYI, Enkei RPF1's 17x8.5 +30 offset with 245/45/17 Dunlop Starspecs have clearance issues. Front wheels rub on back side when turned into the wheel well. The rubbing does not seem severe but I will have to see what the damage is after they have been on the car a while.
Does anybody have an idea why I'm having problems? 245/45/17's were said to fit properly by several members. Would 245/45/17's sit differently on 8" wide wheels vs 8.5" wide? I would think the width and height would be the same.
Old May 20, 2011, 05:51 AM
  #1748
chu
chu's Avatar
245.45 is tall.
Old May 20, 2011, 06:05 AM
  #1749
jbrown's Avatar
245/45 is a little taller than a 235/45, so that's probably why it rubs. I'll bet it looks a little goofy too. They will sit differently on 8" vs 8.5" wheels, but it's a very slight difference and is not the cause of the problem. Also, keep in mind that not every 245/45 is the same size, there is a fair amount of variance on all tires, especially on R-compound tires. What Yokohama calls a 235/45 may be a different width AND height compared to what Continental thinks it should be.
You really should just stick to 235/45 or 255/40.
Old May 20, 2011, 06:43 AM
  #1750
aaparker's Avatar
Won't the width of the 255 tire cause problems as well, or will the difference in height be enough?
Old May 20, 2011, 07:17 AM
  #1751
jbrown's Avatar
It's a delicate balance. it depends on what part of the tire is rubbing and where.
I have run 255/40s on a 17x9 +30 setup and a 17x9 +28 setup without problems, and I've seen plenty of people on here say that they run them on stock wheels without issues.
Old May 20, 2011, 08:09 AM
  #1752
Hikaru's Avatar
+1 With jbrown, the tire height is the issue here. Ive run 255/35 on 18x9 +29 and 255/40 on stock bbs with zero problems and that's even on Dunlop star specs which run large for their sizing
Old May 20, 2011, 10:35 AM
  #1753
bradze's Avatar
how well will 18x10+25 wheels with 275/35/18 tires fit on an evo 9? also, im parting out an evo x, and was wondering if 245/40/18 tires would fit those wheels? friend im probably selling to with an evo 9 doesn't want race tires, but does want my new street tires.
Old May 21, 2011, 03:55 PM
  #1754
Colbyy's Avatar
What kind of tires are recommend for just daily driving in the summer and good in rain. I dont drive the car in the winter kuz well i live in sullivan nh and last year the snow was over the tires on my jeep haha had 3 feet when i came home from work one day. but anyways the car came with winter Pirellis 235/45ZR17. just was lookin for input on what i should get that last too. Thanks
Old May 21, 2011, 08:05 PM
  #1755
jbrown's Avatar
Try the Continental Extreme Contact DW (not DWS). It's pretty decent. Definitely not in the sticky league of a Star Spec or Advan Neova, and definitely not as good as the stock tires, but it's pretty solid in the rain and way more durable than any of those tires.
Quick Reply: Tire / Wheel Fitment Questions
