Tire / Wheel Fitment Questions
Old Aug 5, 2006, 03:41 PM
  #256
lewd43's Avatar
Originally Posted by jbrown
If it's for an Evo, it should work fine.
The worst case would be a cheap 3mm spacer up front.
If it's for the Prelude in you personal info, I have no clue.
nope, not the prelude, its on c2 knock offs lol
im leaving the honda game and getting an evo 9 once i get back to south florida next month.
once i saw these wheels, i knew i wanted them
Old Aug 15, 2006, 11:14 AM
  #257
projekt_shocker's Avatar
18"x9" wheel with +30 offset...
will that fit?
Old Aug 15, 2006, 11:20 AM
  #258
lexat20's Avatar
Originally Posted by lexat20
I have an opportunity for zigen fn01rc in 17x8 35 offset, what is the largest tire I can fit? I am using coilovers
I'm a dumbass. These don't fit an evo unless you want to use like a 1" spacer.
Old Aug 15, 2006, 12:29 PM
  #259
jbrown's Avatar
will that fit?
Too many unanswered variables.
What wheel?
What do the spokes look like?
Are you ok with adding a 5 or 6mm spacer if necessary? At that pont the wheel would stick out a little bit.
Old Aug 15, 2006, 07:30 PM
  #260
MR 600's Avatar
Originally Posted by Andrew LB
I'm looking at some Volk TE37's.
Hey fellas. Will 18x9.5 ~35mm fit? Fender rolling is not an issue with me.
+1 , I also ordered the time attacks in 18X9.5 +34 offset, Will these fit OK? will i need spacers? Tires will be (255 35 18), i also want to install a 355mm big brake kit (Brembo or Stoptech).
Old Aug 15, 2006, 08:15 PM
  #261
wj4
wj4's Avatar
you should be ok. i know some guys with 18 x 9.5 5zigens also with 35offset. also running 255/35/18 and they are nearly slammed on coilovers. they arent rubbing at all and no fender rolling.
Old Aug 24, 2006, 12:11 AM
  #262
hokiruu's Avatar
it's a long shot, and i know it will take some work, but will a 17x9 +22 Super Advan SA3R fit with 055/40/17? i'm pretty sure the calipers are not an issue at all, but i wonder how much camber/roll/pull is necessary and if theat's even enough? Seems about 6mm too low offset than ideal. I dont mind them sticking out bit, i just don't want them rubbing. the fronts are not my concern (b/c pull, wide fenders+camber in front is easy and effective. it's whether i can work around the back fender in this size with less than 2 degrees of camber...
Old Aug 24, 2006, 07:00 AM
  #263
jbrown's Avatar
Most ppl with 17x9's are running close a +35mm offset and from what I've heard, this doesn't rub at all with 255/40 tires. (I am going to order CE-28's in that exact setup for my car tomorrow)
So yours would stick out about 1/2" farther than that, so I would suspect it can be done, but you will definitely need to do some fender rolling, and your steering geometry might be a little weird.
Old Sep 7, 2006, 05:23 PM
  #264
oguratevo's Avatar
I have this set up Volk CE28 17x9 +35mm with 255-40-17 Yoko Advan rubber. no rubbing issues.
Old Sep 11, 2006, 03:56 PM
  #265
BigSkyLLC's Avatar
Any pics w/ 18x9.5 with out spacers, fender rolling or other mods?
Old Sep 12, 2006, 07:29 AM
  #266
hokiruu's Avatar
Whether or not it has spacers shouldn't really matter, because after spacers, you still have an offset. What you want to find out is what offset is required for 18x9.5.
Old Sep 13, 2006, 10:59 PM
  #267
mymroadster's Avatar
Volk TE 37 17X9.5 on evo 9 mr??
hi, is it possible that Volk TE 37 17X9.5 fits on evo mr with out any wide fanders?
if it fits, what off-sets? does it gonna clear calipers? any speacers?
thank you much
Old Sep 14, 2006, 12:05 PM
  #268
jbrown's Avatar
thank you much
Not likely. 17x9.5 comes in a +28 and a +35 that will both clear the calipers without spacers, but I'm pretty sure it will rub in the back if you go any bigger than a 255/40/17, at which point a 17x9 +35 will work great without any rubbing. If you want a 275/40 then a 17x9.5 would be better, but you will have to roll the fenders.
Old Sep 17, 2006, 08:29 PM
  #269
kmcconn9's Avatar
How about a confirmation on the FNO1-RC's in 18x9.5 and a reccomend tire size?
Old Sep 17, 2006, 09:46 PM
  #270
jbrown's Avatar
+35mm offset and a 255/35/18 should be ok. Might need a very small (3-5mm) spacer in front.
Probably will need to roll the fenders to stop what will likely be minimal rubbing.
Quick Reply: Tire / Wheel Fitment Questions
