Tire / Wheel Fitment Questions
Old Nov 23, 2014, 10:13 AM
  #2821
Robdeep3's Avatar
Yeah I'm fine with the rear right now I just need to clear the brakes in the front. The tires on them right now are 235 40 18. Just not sure really for the front if I should run 15mm or will a 10mm spacer be enough.
Old Nov 28, 2014, 12:57 PM
  #2822
03BBY1088's Avatar
I have a question about 18x10 setup, and if i should order the +25 or +15 setup, trying to figure out which ones wont hit the calipers?! any help would be awesome
Old Nov 28, 2014, 02:30 PM
  #2823
Received 1,384 Likes on 1,317 Posts
Im not well versed in anything wider than a 9.5". I usually refer those to this thread which is active now in our motorsports section (depending on offset, serious rear body work & lower control arm mods are sometimes needed)
https://www.evolutionm.net/forums/mo...-body-evo.html
Heres another thread active in this forum if you havent seen it
https://www.evolutionm.net/forums/ev...10-5-30-a.html
See quote above
Old Dec 3, 2014, 03:13 PM
  #2824
NEpsiOver21's Avatar
Sorry, posted in the wrong thread. Didn't realize i was in Evo 1-9 section.
Old Dec 7, 2014, 02:16 PM
  #2825
Sevs9mr's Avatar
I'm 1" lowered in the front and .5 in the rear I was wondering if I can run 18x9.5 without any fender work?
Old Dec 7, 2014, 03:29 PM
  #2826
heel2toe's Avatar
That'll depend on the offset of the wheel as well as the tire you choose to run...
Old Dec 9, 2014, 07:13 AM
  #2827
Mr.C2's Avatar
I'm planning to get some wheels for my EVO 9, the specs are 18x10.5 +19 all around. Not sure what tire I should run. Rear fender has been rolled and my car sit pretty low. I'm currently on 17x9 +15 all around with stretch tires 205/45/17 and it doesn't rub at all. Any suggestions or thoughts on what I need to do or will it work? I'm a little bit confused with the offset and tires needed
Old Dec 9, 2014, 07:45 AM
  #2828
This is just my opinion. These no.s are well outside the acceptable offsets that work on a stock body EVO. Nobody properly runs a 10.5 wheel w/a +19 Cant be done effectively w/out serious rub, super stretch & out of spec camber
Also, running a 205 on a 9" wheel does not meet the min spec. Min spec is 235. No bueno sir.
Read this thread on the 10.5 & it will give you a better feel for the work & offset needed
Old Dec 10, 2014, 09:43 AM
  #2829
Mr.C2's Avatar
Thank you so much for your thoughts and input. Sometime it's hard for me to understand offset and what is a good fitment for stock body Evo going with aggressive wheels. I kinda wanted to be more function and form since I daily the car. Do you have a suggestion or right specs with stock body and how aggressive wheels I can go. I do have coilover with front camber plate and stock rear camber. Any suggestion would help, I just don't have the time to go thru the whole thread to find the specs. I'm more show than go.
Old Dec 10, 2014, 11:15 AM
  #2830
I suggest you go through these 2 threads to give you an idea of what some of the guys are running. Certainly not all the posts are of wheels that are of the proper spec to fit the stock body
Based on what you originally posted & depending on how much rear fender work you can stand, look for a wheel in this range:
18x9.5 / Offset range +25 to +35 / Tire choice 255/35 to 275/35
Unless you want to go the 17" route. Thats what I run
https://www.evolutionm.net/forums/ev...re-thread.html
https://www.evolutionm.net/forums/ev...el-thread.html
Old Dec 14, 2014, 06:03 AM
  #2831
jake33's Avatar
What offset on a 18x8.5 will clear the front calipers on an 04? I've read +30 but then other threads say that it may rub depending on the way the wheel spoke is designed. So what wheels that are 18x8.5 will clear the calipers without spacers needed?
Old Dec 14, 2014, 09:13 AM
  #2832
There is no one specific offset that will clear the Brembos. It has mostly due to spoke design and the wheel area called the X-factor (caliper clearance zone)
Do a bit of research in these 2 threads & find something you like. If you have questions about a particular wheel / offset post up & we will help where we can
Old Dec 17, 2014, 02:54 PM
  #2833
jake33's Avatar
Ah man, this is gunna be alot harder than i thought. I dont want to order 4 wheels and then have them not fit on my car and then have to pay to ship them back, etc.
I was looking at MB Battles and STR 514's. Both 18x8.5 +30. I really want to keep the 8.5 so i can run 245's and get the most out of them. Not really looking for stance, just something better than these ugly 5Zigens.
Should I just call both companys and see if they can confirm if they will fit the hub and not hit caliper? Or do i literally have to test fit to see?
Ive read the other posts' and only found that the RPF-1's will fit with a 3mm caliper clearance (18x8.5 +30)
Old Dec 17, 2014, 03:53 PM
  #2834
Totally understand. Fitting wheels is for sure an art & science. Some great wheels that fit over the calipers are your very spendy Volks / Advans. If youre looking for budget wheels many Rotas fit over the calipers
BTW, speaking of 5Zigens. Not sure which ones you have but the 17x9 +35 5Zigen FN01RC are great wheels that fit over calipers
Old Dec 22, 2014, 05:58 PM
  #2835
nk1124's Avatar
Looking at Volk ce28n 17x9 the only available offsets are +40 and +63 for new wheels. Would either of these fit? would spacers be needed to make them fit?
Quick Reply: Tire / Wheel Fitment Questions
