Tire / Wheel Fitment Questions
Old Sep 18, 2006, 05:57 AM
  #271
kmcconn9's Avatar
the tire wont be stretched with the 255 width correct?
Old Sep 18, 2006, 11:12 AM
  #272
jbrown's Avatar
All of the 255/35/18 tires listed on TireRack will fit an 8.5-10" rim, so 9.5" shouldn't be a problem.
Old Sep 20, 2006, 12:04 AM
  #273
SilverStreaker's Avatar
Does the OZ Super III's come in Black for the EVO? I viewed them for the Evo on tirerack and it only showed the Silver ones.
Thanks!
Old Sep 20, 2006, 04:55 AM
  #274
Neal@tirerack's Avatar
Not yet. The black finishes are mainly BMW, Corvette, and Porsche fitments at this time. Haven't heard if they are going to start black in other apps yet. I think they are testing the waters to see what happens.
Old Sep 24, 2006, 11:52 AM
  #275
e8
e8's Avatar
will te-37's fit in 17x9 +22 without rubbing issues or having to use spacers?
Old Sep 24, 2006, 10:11 PM
  #276
jbrown's Avatar
Hard to be certain since you didn't specify a tire size. You definitely won't need spacers anywhere, but they will probably rub in the back. Especially if you run 275/40. There's a slim chance a 235/45 will clear, otherwise light fender rolling should fix it. The fronts should clear without an issue.
Old Sep 26, 2006, 02:20 AM
  #277
E_vo_lu_tion's Avatar
Will 18x8.5 + 40 Enkei RPF-1 fit perfectly with Evo IX?
Old Sep 26, 2006, 06:51 AM
  #278
jbrown's Avatar
Most of the Enkei's need a spacer in front. Call Josh at ImportImage to be sure, he knows a lot about the Enkei wheels.
Old Oct 5, 2006, 09:29 AM
  #279
lexat20's Avatar
I have a Nitto NT01 I want to mount in size 245/45/17. I tried to mount to the stock wheels but it rubbed on the inside wheel well up front. I think if I used a 17x9 FN01rc w/ a 35 offset it would clear. Any body any experience? These tires are amazing but I have nothing I can put them on.
Old Oct 7, 2006, 11:51 PM
  #280
andross85's Avatar
i am going to run advan rs 18x10 on widebody car? what should the tire size be?
Old Oct 7, 2006, 11:52 PM
  #281
Speed Element's Avatar
depending on brand/size tires.
generally, you want to run 265s or 275s on a 10" wide rim.
Old Oct 7, 2006, 11:55 PM
  #282
andross85's Avatar
can you post your rs rims and tire spec on your voltex evo?
Old Oct 8, 2006, 12:00 AM
  #283
i will be running 18"x10.5" 5x114.3 +15 Volks.... the car is currently running the 18x9.5 enkei w/ 265/35/18 RE050 tires.
For 10.5, 275/35/18s for sure.
Old Oct 8, 2006, 12:06 AM
  #284
andross85's Avatar
I thought you are going to run Advan RS 18x10, what change your mind to volks?
will this fit the stock brake and lightly rolled rear fender: 275/35/18s advan rs 18x10 +15 (GTR face) ?
Old Oct 8, 2006, 08:43 PM
  #285
jbrown's Avatar
Not gonna work.
I have the 17x9 FN01R-C as my track wheel with a 255/40/17 Toyo RA-1 and they clear the fender iners, but are a bit close. A 245/45 is taller than my setup and the increased width combined with decreased offset will push the wheel FARTHER into the liner whenever you turn. You would actually be making it worse for yourself.
You basically just have the wrong tire size. With a 6mm spacer in the front, my setup clears fine. I only needed the spacer because the tires were rubbing on my coilovers, I think if you have stock suspension, the rims would clear just fine, but your tire size isn't gonna work no matter what..
Quick Reply: Tire / Wheel Fitment Questions
