Tire / Wheel Fitment Questions
#2836
^^^I would steer clear of both =)
As you may know, the stock offset is +38. IMO, your first goal should be to find a set of wheels that do not require spacers. If you have to go the spacer route look to the proven sets like Enkei RPF1s / NTO3's etc
Look above a few posts (post 2826) & click on those wheel links. Find something proven that you like & we can talk later about fitment
#2839
Hey guys, I'm wondering is 18x10.5 with +15 Work Crs will tuck on stock body? I highly doubt it but im just looking around. Im guessing the tire would have to be like a 245 40 or 35 to fit. Btw im on bags.
#2840
10.5 possible, +15 no way
https://www.evolutionm.net/forums/mo...-body-evo.html
#2841
I haven't heard of anyone using 16" on Evo 8, but seeing if it would work. I found a set of Buddy Club P1 rims locally, its 16X7 with +22 and +33 offset. Just going for the lightest possible setup and still clear the breaks. Going from 17 to 16 should save me a couple pounds of unspung weight. I am also trying to avoid spacers if possible. Thanks in advance for any help
#2842
Check out this thread
https://www.evolutionm.net/forums/dr...l-fit-evo.html
#2844
Cheers
https://www.evolutionm.net/forums/ev...8n-thread.html
#2846
Advan RS
Looking to buy a set of advan rs. I noticed a lot of guys on here run 18x9 +29 offset. Is there any other wheel size/ offset I can run without running spacers or fender rolling.
#2847
I run a similar Advan. RGII 17x9 +29 running 275/40's. No spacers on these as well & they weigh approx 16.8#'s
Not sure of the other offsets. +29 is aggressive enough as I needed some relatively extreme rear fender work to get that pkg to fit
Your 18x9 +29 will require at min a roll depending on tire choice
