Tire / Wheel Fitment Questions
#2941
#2942
The searching I did shows all high offset XXR's will need a spacer. The wheel noted by you is very, very conservative in width & offset. Personally would rather see a more aggressive choice
Heres a search string which may give you some ideas:
https://www.evolutionm.net/forums/se...rchid=21632930
#2946
#2950
Now, Im not sure of how the wheel fit over the front Brembos (most wheels dont w/out spacers)
#2951
Hi all,
Wanting to buy some street and track rims
Volks TE37 is my choice
1) 17x9+28 will these fit comfortably for track work with 255/40/17 semis tire? I.e no rubbing under any normal track load
2) 18x9.5+22 will these fit 255/35/18 or 40 profile with rear guard work and have to relocate the rear bumper bolt? This setup for street.
And would I need to run ridiculous amounts of camber?
3) I have had Wed sports tc105n in 17x9+35 and volks re30 18x9.5+22 and both these specs require 3mm spacer up front to fit. Will my two specs above 1 and 2 for TE37 clear it better because of rim design and no longer require spacers?
Thanks in advanced
Tony
Thanks in advanced
Tony
#2952
Hi all,
Thanks in advanced
Tony
Thanks in advanced
Tony
1. Layed this out on the calculator. Running a 255/40 on a +28 will require a rear fender roll, a pull & the bumper bolt move. +28 is aggressive & the 255 is the perfect choice for a 9"r
2. 18x9.5+22 running a 255/40/18. The rear fender work noted above will be needed here as well but even more roll & more fender pull. Doable, but your rear fenders will likely show the fender pull (slight crease)
3. Some Volks are very Brembo friendly & Im not 100% sure these TE's fit. Comb over this thread here & see if you can find a post with your size
https://www.evolutionm.net/forums/ev...37-thread.html
#2954
The +25 offset wheel for sure will need the full rear fender treatment. Fender roll, pull & bumper bolt needed
The 255/35 tire is a good, modest choice
Cant help w/the front Brembo caliper clearance. Make sure you test fit or have received good info of front caliper fit
