Tire / Wheel Fitment Questions
Old Nov 16, 2016, 01:12 AM
  #3301
eddy5201314's Avatar
hi guys can anyone tell me what I can do if my tyres rubs the inside fender when I fully lock? I did some research and found that I could use a heat gun to fix this? But How? Thx
Old Nov 16, 2016, 06:17 AM
  #3302
Received 1,384 Likes on 1,317 Posts
This topic is being discussed here:
https://www.evolutionm.net/forums/ev...l#post11683424
Old Nov 16, 2016, 08:23 AM
  #3303
kyoo's Avatar
Originally Posted by orion4096
ssr gtv02 17x9 +38 fit with a 3mm spacer. Without the spacer, the inside edge (closest to the hub) of the front calipers are touching the spokes. With the spacer there is about 2mm of clearance. I have 255/40/17 rs3v2s on the wheel.
guess my answer's here - would require a spacer. not interested in doing that
Old Nov 16, 2016, 01:03 PM
  #3304
kyoo's Avatar
so right now I'm looking at a few options
volk ce28n (ce28sl? what's the diff?)
gram lights 57transcend
wedsport tc105n
all 17x9, +whatever it takes to fit. I'm leaning towards the wedssports..
Old Nov 16, 2016, 08:08 PM
  #3305
kyoo's Avatar
distributor said only ce28ns he sees in 17x9 are in offsets +40 and +63? that can't be right can it?
Old Nov 17, 2016, 02:34 AM
  #3306
kjcs9's Avatar
Just an update with my current wheel setup.
Previous are rota gkr 18x9 offset +36 (i guess) on 245/40 tires. Used 25mm wheel spacer adaptor upfront for flush look.
Im now running on square 18x9.5 offset +30 rota IKR (not sure if same with grid, mine are concaves)
tires are 265/35
I used 12mm spacers upfront to clear the factory brembos. Had no choice but to use spacers since this set are concaves that's why I cannot clear the brembos. I was forced to have the factory wheel studs replaced with longer sets upfront since the theead of factories are no longer sufficinet due to the 12mm plate spacers. Also used voltex street wide fenders to have a flush look. Still having a little rub upfront when steering in full.
No problems with the rear.
Will post pictures later.
Old Nov 17, 2016, 03:48 AM
  #3307
kjcs9's Avatar
Crappy photos....
Old Nov 17, 2016, 05:07 AM
  #3308
Those are not going to work. Looks like S2K type offsets. Steer clear of those!
Old Nov 17, 2016, 05:15 AM
  #3309
tires are 265/35
Set up looks very aggressive & like the look The rear ride height could be a bit lower with too much gap IMO. What rear fender work was done because it appears you may need a rear roll w/those 265's & the +30
Old Nov 17, 2016, 06:35 AM
  #3310
kjcs9's Avatar
yup. might still play with height and camber adjustments.
fortunately still no rear fender work was done so I still have allowances. might get a voltex rear kit and sides for this. will just run on spacers for the rear.
Old Nov 17, 2016, 07:53 AM
  #3311
kyoo's Avatar
yeesh. I guess it's just the ce28sl's that come in the right offsets then.
Old Nov 17, 2016, 09:52 AM
  #3312
kyoo's Avatar
it's too bad I dislike the rpf1's. I can get 17x9s for about $900. looks like the come in +22 and +35, +22 is probably safest for clearing the brakes, and will just require a roll.
okay based on what I'm seeing - 17x9 +22 won't clear the brembos? I'd have to do 17x9.5 +18s to clear the brembos, which would be a nightmare fitment in the rear is that right? I'd have to get +38s, and run a 20mm spacer in the front?
I'm leaning towards the CE28SL's - I wanted the RE30 club sports but it looks like they don't come in the right offset. So, CE28SL in 17x9 +22, or 17x9.5 +28 - if both fit I think the 17x9 is more appealing to me, less lip/concavity that I detest
Old Nov 17, 2016, 06:37 PM
  #3313
Kyoo, you are on the right track. Yes, the +38 RPF1's need a least a 20mm spacer. I like them as well but the spacer really pushes out the fronts
What about the new Advan RGD? 17x9 +29?
Old Dec 10, 2016, 03:58 PM
  #3314
jwalleg's Avatar
Does anyone know what offsets ssr gtx01 fit?
Old Dec 10, 2016, 06:22 PM
  #3315
Did a search here & did not find any hits on the GTX wheel. If you can give me a size youre interested in I will do the math for you & let you know what type of work will be needed to fit
If you want an idea, look for something in these ranges. 18 x 9 / 18 x 9.5 / 17 x 9 / 17 x 9.5 in the +25 to +35 range
Quick Reply: Tire / Wheel Fitment Questions
