Tire / Wheel Fitment Questions
#3316
I am planning to purchase XXR 527 18X8.75. It seems like some have +20 offset while others recommend +35 offset. I do not mind rolling rear fenders but will this setup clear front brake calipers? Any idea which is better setup +20 or +35?
Thanks
Thanks
MinusPrevious (Dec 12, 2016)
#3317
You will need more than a rear roll to get this to clear the rears properly.
The +20 is really a show offset & not considered practical fitment for the stock body EvO
Front fitment will likely need a spacer to fit
Heres a search string for you to get more info from others running the XXR's
https://www.evolutionm.net/forums/se...rchid=23438886
s0hn (Dec 12, 2016)
#3319
That is a good size
I ran these no. for you on the calc. 18x9 + 35 running a 255/35
Results: Rear roll needed (3/4 roll. not flat). No bumper bolt relocation needed / Stock rear -1 degree camber OK
Front fitment ok w/no fender work needed. Front spacer is likely!
#3320
I'm looking for some help with a Work wheel fitment.
Work Meister S2R 17x8 +35
I plan on running just an OE 235/45/17 sized tire. Seller says they will clear the brakes but I would really appreciate if anyone on the forum has experience. My car is an 01 JDM Evo VII but should be the same as any of the USDM Evo's.
Thank you.
Link to craigslist post: http://seattle.craigslist.org/see/wto/5918488256.html
Thank you.
MinusPrevious (Dec 20, 2016)
#3321
Thank you.
Thank you.
The spoke design is certainly caliper friendly but I would be surprised if they cleared
mctonyb (Dec 20, 2016)
#3323
18 x 9 with offset +30, do you guys think this will require spacer? or roll fenders? still not sure what size of tires i should go with this setup but before purchasing this wheels, i wanted to verify if this will be a good fitment for evo 8.
#3325
Appreciate it.
#3326
Generally, An 18x9 +30 is a good wheel for the EvO rear fender but running a 255/35 tire, a light rear fender roll will be needed
#3327
There are a no. of 17" wheels that do clear. Rotas /5Zigens/ Weds/ Advans /Buddy club to name a few
I run the following 17's that clear the calipers (Rota P45 17x9.5 +30 / Advan RGII 17x9 +29
#3328
Unknown about the caliper fitment unless we know the make / model of the wheel & we have fitment history
#3329
The only RPF1 that clears the front caliper is the +18 from what I remember
Have you gone through these threads for some Ideas?
https://www.evolutionm.net/forums/ev...r-enkei-s.html
https://www.evolutionm.net/forums/ev...nkei-rpf1.html
#3330
Fitment check?
Cosmis XT-206R 18X9.5 +10
Nitto NT05 265/35r18
Front and rear fenders are rolled and pulled, I'm on bilsteins with lowering springs. Will I be able to make fitment with this setup? Advice?
