All Wheel/Tire Fitment Guide and Questions Go Here - Page 224 - evolutionm.net
Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack Discuss everything that helps make your car start and stop to the best of it's abilities.
Sponsored by: Tire Rack
Thread Tools Search this Thread
Old Mar 2, 2017, 07:03 AM   #3346
Drives: 2001 Evo7, 1995 R33 gtst
decided to get some enkei rpf1's
i am getting the 17x8.5 +30 size, these should fit wheel and spacers wont be needed right?
Offline
Old Mar 2, 2017, 07:46 AM   #3347
EvoM Moderator
Drives: 2006 ランエボ RS
Looks like that will work w/out a spacer per the comment in this thread
Fitment Q: RPF1 17x8.5 +30, Z1* 255/40-17
Offline
Old Mar 2, 2017, 10:07 AM   #3348
Drives: JDM EVO VII
I'm narrowing down choices for 17's for my car and because I'm in Canada I'll be ordering online. More than likely they'll be from the US so confirming fitment is crucial as returns are really tough/expensive. This thread the the people that contribute are a huge asset, thank you.
I really don't want to roll/alter the fenders on my 2001 JDM EVO VII so fitment without modifications are crucial.
Great to see the Enkei RPF1 17x8.5 +30 with 235/45/17 will fit without any problems. These are probably my #1 choice.
I've seen mixed reviews on one of my other choices, Rota Grid's in 17x9 +25. Most run a 255 width tire though, I know it's a stretch, but I'm wondering if they'll fit with 235/45/17?
Lastly; I'm looking at Advanti Storm S1's in 17x9. They make a +30 and +35 both strong and lightweight at a good price point. I'd just like to confirm fitment and there's not much info? Again I'd be running 235/45/17 tires.
Offline
The Following User Says Thank You to mctonyb For This Useful Post:
MinusPrevious (Mar 2, 2017)
Old Mar 2, 2017, 10:51 AM   #3349
EvoM Moderator
The EvO7 has the CT9A platform so:
The 17x9 +25 will definitely need a rear roll
The 17x9 +35 would be your best bet, based on your notes above (i.e. no rear roll)
The stock size 235/45 will certainly help eliminating the need to roll the rears
Front fit will be no problem on any of your scenarios except that a front spacer maybe needed on these wheels. No way to tell if a spacer is needed unless you have prior knowledge from others
Would like you to reconsider the rear roll. Its the only way to get a decent width tire in the rear.
You really should consider running a 255/40 tire
Offline
The Following User Says Thank You to MinusPrevious For This Useful Post:
mctonyb (Mar 2, 2017)
Old Mar 20, 2017, 01:45 PM   #3350
tbaird58's Avatar
Drives: 03 silver evo 8
Curious if anyone knows if the works d9r 18x9.5 +12 would clear on an evo 8? Can't seem to find anything
Offline
Old Mar 20, 2017, 06:31 PM   #3351
EvoM Moderator
Quote:
All the function guys that monitor the wheel threads will politely advise you to stay away from these low offset wheels
Try & stay within the +25 to +38 range (even +25's w/wide tires (255 & above) is tough to fit correctly
Offline
Old Mar 20, 2017, 07:44 PM   #3352
tbaird58's Avatar
after looking around i found +30 which is what i would want, i only posted about the 12s because i couldnt find any other offset on the site i was on.
so if anyone has any info on those +30 i would appreciate it.
Offline
Old Mar 21, 2017, 05:29 AM   #3353
EvoM Moderator
^^^18x9.5 +30 is a size similar to what I run. Lets say you run a 265/35 tire. This recipe will require a rear fender roll combined w/a slight pull.
Also, the bumper bolt will have to be relocated further back. Rear camber setting set at -1.8 degrees max
Please note: Front caliper fitment is unknown
Offline
Old Mar 23, 2017, 12:25 PM   #3354
awhit17's Avatar
Drives: Wicked White Evo IX MR
I'm looking around at 18x10 +35 with a 275...I know these will require offset arms in the rear. Will these hit the strut in the front without a spacer? I know it has to be close.
Offline
Old Mar 24, 2017, 01:40 PM   #3355
EvoM Moderator
Quote:
Here are a few threads that discuss this. It is doable
My expertise ends at the 9.5" wheel width & 275 wide tire
275 35R18 Slick on NT03 10.5 stock body Evo
18x10's
Offline
Thread Thread Starter Forum Replies Last Post
Verified Tire/Wheel Fitments (only) Iowa999 Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 6 Jun 8, 2012 10:51 PM
Verified FAILED Tire/Wheel Fitments (only) Iowa999 Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 3 Jun 7, 2012 12:35 PM
light-weight rims list evolutong Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 1 Feb 27, 2010 05:50 AM
Winter tire options - best recommendations ksattic Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 58 Dec 25, 2008 08:48 PM
Lux Rims Dorikun Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack 3 Sep 2, 2008 12:57 AM
Tags
04, 10, 15, 17, 17x10, 17x9, 18, 18x, 18x10, 18x1038, 18x105, 18x10515, 18x8, 18x9.5, 18x95, 19x85, 22, 245, 24545, 25, 255, 2554017, 275, 29, 31, 35, 38, 40mm, 5x100, 5x45, 5zigen, 95, a4, advan, audi, b5, bbs, bmw, bolt, ce28, ce30, enkei, enkie, es, et38, evo, evolution, fit, fittment, fn01, fn01c, fn01r, fn01rc, grid, grid's, help wheel fitment, honda, ix, konig, konig lace, lace, lm, mazda, model, mr, offset, offset., pattern, perfect, pics, prelude, racing, rear, rgii, rims, rota, rpf1, rs, rsx, saab, sale, size, sti, strength, subaru, tire, tire size, tire size for volk re30, tires, tyre, volk, vw, wats, wheels, widebody, x85, x9
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
