Tire / Wheel Fitment Questions
Old May 13, 2004, 12:26 PM
  #31
GotBoost25psi's Avatar
Originally Posted by jwtodd60
Volk CE28N-L in 17x8, +33mm fit...
JW
i would love to get some of those in 18's they look really tight! they look great on a yellow evo!
Old May 19, 2004, 11:12 AM
  #32
stocky's Avatar
@ Neil:
Which is now the correct offset for the 18" SSR competition to fit
Thanks,
Yves
Old May 19, 2004, 11:24 AM
  #33
Neal@tirerack's Avatar
We currently sell that wheel in an 18x9 with a 44mm offset, supplied with a 5mm spacer. This gives it a 39mm when its all said and done.
Old May 19, 2004, 11:47 AM
  #34
stocky's Avatar
@ Neal:
Thanks for the quick answer but you are stating on the previous page that you now offer the SSR comp without spacers! ?
Old May 19, 2004, 11:53 AM
  #35
I'm sorry, my mistake. I was looking at the GT-3. Whew, need more Dr. Pepper
The non-spacer Comp we carry has a 32mm offset
Old May 22, 2004, 04:51 AM
  #36
Pesto360's Avatar
[QUOTE=Neal@tirerack.]
OZ Superleggera III
**Requires a 3mm spacer for proper fitment**
[QUOTE]
Neil...
OZ Superleggeras actually do not need a spacer I had the first set for the evo and they fit perfect....no spacer needed.
Old May 22, 2004, 04:56 AM
  #37
Pesto360's Avatar
Superleggeras NO spacer
Here are pics of it
https://www.evolutionm.net/forums/sh...ad.php?t=55098
Old May 22, 2004, 05:27 AM
  #38
Shaitiger's Avatar
I have a buddy that wants to go 265/30/19 with 19x9 RacingHart Pro J5 wheels. The offset of the wheels are +35mm. The height of the tires are identical or less then the stock 17" tire overall diameter and the 265 is one inch wider than the stock 235/45/17s. Will these fit with a minimal drop or on stock suspension?
Old May 29, 2004, 05:13 PM
  #39
Evo8DownUnder's Avatar
Originally Posted by AWD 20T
What size tire must I run on an 18x9" wheel? Is fender rolling required?
And again?
Is there a CONCISE thread on this board that gives advice (ACCURATE advice) about what tyre sizes suit what rims?
For example, if you run 18 x 8, the correct tyre to give the same rolling diameter as stock is???
If you run 18 x 9, 19 x 9 etc etc
I'm looking for a set of Volk GT-7s for my new Evo, possibly 18 x 9s (is that size available in GT-7s), what tyre size do I use to get the same rolling diameter as stock and not rub the fender linings? I also want to give it that 'fat' look, so what offset should I use to get that look but remain under the fenders?
Simmons Wheels in Australia do sweet rims, btw.
Old May 29, 2004, 06:45 PM
  #40
Shaitiger's Avatar
Go to Tirerack.com and see the specs for each tire. That will let you compare the stock 235/45/17 tire overall diameter with others. The stock tire overall diameter is 25.3". Go from there.
I still haven't got an answer regarding my question and my question has been up here for a whole week.
Old May 30, 2004, 11:55 AM
  #41
Mach V Dan's Avatar
Regardless of lowering, a 265 is a huge width, and I doubt it'll fit without rubbing the fenders (or even the strut). Most cars I have seen with 255 width had rubbing issues.
--Dan
Mach V
MachEVO.com
Old May 30, 2004, 01:26 PM
  #42
Shaitiger's Avatar
What exact tire size did those folks who were having rubbing issues go with?
I didn't know an inch added onto the stock width was a "huge" width.
Old Jun 15, 2004, 07:21 PM
  #43
evojoe73's Avatar
Just Ordered ALT Racing AT-298 X-factor rims, 18X8 with a 42mm offset will i have any problems with these fitting my EVO? Also what tire should i use, size and brand. Thanxs for your help everyone!
Old Jun 19, 2004, 09:59 AM
  #44
Eva01's Avatar
19" is the only diameter that will let Racing Harts (any model) clear the calipers. 18" is several mm too small.
Currently waiting on a set of 4 Enkei OR52 rims. They will be 18x8, 5x114.3/120 bolt pattern with a 35mm offset. Will not know till I get the fronts on to see if only the front will require a small (<3mm) spacer. Backs fit without adjustment.
This is with being fitted with 4x BF Goodrich T/A KD 225/40/18 tires.
Eva01
Old Aug 4, 2004, 12:50 PM
  #45
gldenchld's Avatar
Privats work well
Fahrens and Profils 17x8 , 18x8 , 18x9
either silver or gloss black
Quick Reply: Tire / Wheel Fitment Questions
