Tire / Wheel Fitment Questions
Old Aug 4, 2004, 01:30 PM
  #46
MalibuJack's Avatar
Let me add that 18x9's fit with the 40mm offset on the Privat Fahrens..
Old Aug 5, 2004, 12:38 AM
  #47
RuckerPark's Avatar
Still love those NT-03RRs.. can't find the Road Race version of the NT-03 in the States at all.. JDM only..
Old Aug 12, 2004, 09:04 PM
  #48
escoson's Avatar
confirmed:
http://www.gruppe-s.com/Advan/advan_evo.htm
http://store.finalstageauto.net/whandtipa1.html
Old Sep 19, 2004, 10:17 PM
  #49
Evil EV0's Avatar
Dont know if these have been mentioned, didnt read the whole thread.
I have 17x8 5Zigen Typhoons with a +27 offset and am running 245 tires. They didnt need any spacers or hubcentric rings...Heres a pic
Old Oct 1, 2004, 09:49 PM
  #50
AlwaysinBoost's Avatar
Originally Posted by berkel
Hi,
I'll start. Please let me know if anything needs to be changed or edit it for me.
Wheel: Enkei RS-5
Size/offset: 17x7 5-100/114 40
Price: ~140$/wheel from Discount Tire
These are a 5 spoke design. I was surprised that a 17x7 wheel fits, but it does. Clears calipers by a mm or so. I drove around with the windows down to make sure it wasn't rubbing when turning or braking.
I'll add some weight info as well. On my bathroom digital scale, the stock Enkeis with ~60% worn advans and lots of brake dust weighed 44 lbs (no lug nuts). The Enkei RS-5 with brand new 235 45 17 Falken Z1-EX all seasons weighed 43 lbs.
Here is a pic on my car:
<edit>
Per jbrennan's post here is more info:
Hubcentric rings were required and provided by DiscountTire in my case. Also provided were gorilla lug nuts.
</edit>
Take care,
FB
does anyone know if a 5x100 bolt pattern will fit? all the posts I've seen reference 5x114.3...
Old Oct 3, 2004, 07:27 PM
  #51
gldenchld's Avatar
an Evo is 5x114.3 not 5x100 , you might have seen a dual drilled wheel that is referred as 10 hole , meaning it will fit both bolt patterns.
JapaneseMuscle (Jan 31, 2022)
Old Oct 5, 2004, 06:04 PM
  #52
RED DEMON's Avatar
Ekkei PK6
Just took these, in silver, OFF my evo. Didnt like the silver so much and decided to go with the gunmetal with polished lip, waiting for them to arrive in about a week. Rims are 18x8.5 Enkei PK6s
(Picture attached)
Old Oct 5, 2004, 08:44 PM
  #53
Eva01's Avatar
The Advan TC-II's you see here:
are the same thing as the Axis Reverbs. As a matter of fact, I think Axis makes them for Advan. They are the same identical wheel and the Axis version is $300 a wheel while the Advan sells for $682 in the 18x8.5 version. What a rip off!
Just to add to this guide, I have Axis Reverbs 18x8.5 with a +35 offset. THey fit perfectly and clear the front by at least 1 cm. The back is even better of course.
Eva01
Old Oct 7, 2004, 10:59 PM
  #54
NocturnalEVO's Avatar
I'm looking to get SSR SP1 Professors on my evo.
I want to go with a 18x8.5" size, but i'm also considering going with a 18x9.0" size.
But most probably I will go with the 18x8.5" size.
What offset would be best for me? and what size tires should I go with?
Thanks!
Old Oct 8, 2004, 06:09 AM
  #55
Neal@tirerack's Avatar
Thanks!
We will be carrying that particular wheel for the EVO soon. It will be brought in under the name Speed Star Wheel rather than SSR. Reason being these wheels are from their cast multi-piece line rather than the semi solid forged line up. To differentiate the two, they are using SSR for the forged line and Speed Star Wheel for their cast line.
That wheel has a tapered lip which means the center is 1" smaller than the outside. For example, the 18" wheel actually uses a 17" center. Its lighter than a GT-3 in the same size because of the smaller center.
I'll try to get availability dates for you
Old Oct 8, 2004, 07:18 AM
  #56
The answer came faster than I thought! Looks like we will have these in an 18x8.5 and 19x8.5, both with a 37mm offset.
Also got word that the new Speed Star Wheel D-Racing DSR will be made in a fitment for the EVO. Should have more pics and info on our site soon!
Old Oct 14, 2004, 11:31 AM
  #57
EvoRicer's Avatar
Hey anyone know if a Volk TE37 19x9.5 or 19x10.5 will fit the evo anyone wanna test it out for me? heh
Old Oct 16, 2004, 12:46 AM
  #58
RSVIII's Avatar
hey does anyone know if 17" enkei RSV's will clear on my evo?
Old Oct 22, 2004, 07:33 AM
  #59
cleanevo's Avatar
I know a 17x8 with a 35 offset fits , cause that is a stock wheel size , but what about a 17x9 with a 38mm off set for a rear .
Old Oct 22, 2004, 07:44 AM
  #60
jbrennen's Avatar
Originally Posted by cleanevo
I know a 17x8 with a 35 offset fits , cause that is a stock wheel size...
Actually, stock offset is 38mm -- unless you are referring to the MR's wheels (I have no idea what the offset is on those). A 17x8 wheel with 35mm offset would sit 3mm outboard of the stock rim position. Also, not all such wheels fit -- a lot of 17x8 wheels with 38mm offset (or even with 35mm offset) fail to clear the front brake calipers.
In general, simply knowing the wheel's diameter, width, and offset is not enough -- those won't tell you whether the wheel will clear the front calipers.
Quick Reply: Tire / Wheel Fitment Questions
