Fitment Q: RPF1 17x8.5 +30, Z1* 255/40-17
Car is lowered on Swift Sports (stock struts). Will I have any issues running Enkei RPF1 17x8.5 +30 and Dunlop Z1 Star Specs in 255/40-17?
Tirerack says that wheel with stock sized 235/45-17 Star Specs will work.
According to this post: https://www.evolutionm.net/forums/4149733-post23.html I suspect this combo will work.
Thx!
Thx!
1 Post
Depends on your alignment. How much negative camber will you be running in the rear? My car is not that low but I have the same rim & tire size setup. I am only running -1* camber in the rear & it slightly rubs on bumps/etc. Nothing in the front rubs.
Those wheels in that width and offset will fit with no spacers or fender rolling. Those tires should also fit as most 255/40/17 tires will fit granted some tires are wider than others and without super low offset wheels.
I wish you knew your alignment specs...In the future, I take my car to Lester over at Apex Automotive in Marlborough and he does a great job. Hit up Turco and he'll tell you
And yeah my concern was that I've heard the Z1*s tend to run wide
Viegasjuice
16
Aug 5, 2014 06:23 AM
tmaddox
15
Oct 14, 2013 12:22 AM
