Koni 2 way adjustable vs Bilstein MR
Hi guys,
The other day I picked up a set of cheap Koni (yellow? - they're an orange color though) 2 way adjustable struts which were built for the Evo 9 by Koni. Ralliart (which used to supply aftermarket parts for the Evo here in OZ) got Koni to design these struts specifically for the Evo 9, they also came with some "Ralliart" springs, I'm not sure who made these springs.
I also have some Bilstein MR suspension which I planned to equip with some Swift Spec-R springs however now I can't decide between the Bilstein MR + Swift Spec-R combo and the Koni 2 way adjustable + whatever spring combo.
Basically I want to know which shocks are better, it is almost impossible to find information on these "Ralliart" Konis as RRP for them was expensive here in Australia and hardly anyone has them so nobody can provide a comparison.
Would anyone be able to provide some insight, someone who has experience with Koni and Bilstein shocks in general?
Ralliart: 280lbs f / 307lbs r. 0.5f / 0.5r
Swift Spec Rs MR: 358lbs f / 380lbs r. -1.4, -0.66 drop.
Orange are the Sport Konis. Different than the yellows.
For the track, I would run the Swift SpecRs.
And not completely true about stiffer being better around the track. Bilsteins do a great job taking in track imperfections. More your tires are on the ground, better you are.
Regarding the orange colour, I thought that the Sport ones (orange) weren't adjustable? This lead me to think that they might be Yellows (despite the orange colour).
After some research I've found that the Ralliart springs are:
Front 400-550lbs
Rear 400-500lbs
Progressive rate springs
Going by these figures would you now say that the Ralliart springs are actually better?
Front 400-550lbs
Rear 400-500lbs
A number of suspension options were developed in-house by TMR Australia.
You'll need to contact them to confim rates on your konis, but TMR did produce springs for the bilsteins with those rates because I have them in my car (note: they drop suspension a tad and are progressive).
These sound like your dampers:
http://www.tmraustralia.com.au/article.php?ref=90
http://www.tmraustralia.com.au/article.php?ref=63
Cheers.
Cheers.
Deano_Engineer_
Nov 7, 2016 04:31 PM
NFSLancerRA
83
Apr 4, 2015 03:51 PM
project_lancer
47
May 19, 2013 03:18 AM
