WedsSport TC105n 17x9 +35
Old Mar 26, 2015, 05:10 PM
  #31
Abacus's Avatar
Pulled the trigger on some 17x9 et35 Tc105N's after contemplating for a year. I wanted something lighter then stock and good looking. Couldn't be happier.
On my scale they weighed 16lbs . I bought some continental extreme DW 255-40-17 tires (23lbs) because I wanted something lightweight and good handling.
The tires/rims weighed 38.6lb on my scale . My evo 9 BBS with bald 235-45-17 RS-3's weighed 40lbs on that scale as a comparison .
These rims will require at least a 3mm spacer to clear the front brakes. I'm running stock studs and there is plenty of thread with a 3mm spacer. If I was going to track these wheels I would get a hubcentric spacer made for piece of mind.
The car drives nicer with new tires and seems to accelerate easier then before. I attribute that to the difference in size and weight . I went from a 25.3" to a 25". I have a 4.11 gear so anything smaller helps .
Attached Thumbnails WedsSport TC105n 17x9 +35-img_2093-201_zpsvdyszl30.jpg   WedsSport TC105n 17x9 +35-img_2104_zpspwff9xqg.jpg   WedsSport TC105n 17x9 +35-img_2094-201_zpsvfhbwlj4.jpg
Old Nov 16, 2016, 01:26 PM
  #32
kyoo's Avatar
more pics?
Old Nov 16, 2016, 02:44 PM
  #33
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Lots in his build thread.
https://www.evolutionm.net/forums/pr...-2themoon.html
Old Nov 17, 2016, 08:12 AM
  #34
kyoo's Avatar
thanks.
best vendor to pick these up from?
Old Nov 17, 2016, 09:12 AM
  #35
I would say whoever has the best price. I think STM can get them, Evasive Motorsports RavSpec, TF Works. STM is a site sponsor though.
Old Nov 17, 2016, 09:50 AM
  #36
kyoo's Avatar
thanks. I'm reaching out to a few. one vendor is saying no spacer required for +35s too, and a pretty decent price jump at +25. I can be patient though
Old Nov 17, 2016, 11:25 AM
  #37
I would get the +35. Its a good fitment on the car.
Old Nov 17, 2016, 12:28 PM
  #38
SWOLN's Avatar
+1
Old Nov 17, 2016, 01:55 PM
  #39
heel2toe's Avatar
+2. Itll tuck em much better in the rear and Id bet the +25 has a "ricey" lip as you put it relative to the higher offset variants.
But whats up with the stated 3mm spacer needed up front? Im kinda surprised to hear that but guess a lot is dependent on spoke design in conjunction with offset.
Old Nov 17, 2016, 02:03 PM
  #40
kyoo's Avatar
well price difference for +25 is about $100, and that's only cuz the +35s are on sale. I'm really leaning toward +25s here, if not ce28sl's lol.
http://wedssport.jp/spectable/tc105n.pdf
according to the website, the "face" for both the +25 and the +35 are identical. the face types are below:
http://wedssport.jp/products/english/tc105n.html
to see the FR face. all this hunting has made me realize - s2000 guys are super lucky if they like flatter, non lip non concave wheels like I do lol
I'm rolling the fenders, rears at least so I can fit the +25s, so I have to imagine i'll be fine with rear fitment on these. I'll be running the 255/40-17 re71rs, but re71rs don't really run that wide, or tall.
Old Nov 17, 2016, 03:43 PM
  #41
kyoo's Avatar
can we confirm the +35s NEED a spacer to clear the brembos?
https://www.evolutionm.net/forums/ev...ml#post9265494
eh just confirmed with abacus - they will require spacer for +35
Old Nov 17, 2016, 03:50 PM
  #42
yeah... a 3mm. You can run that on the stock studs..
Old Nov 17, 2016, 03:54 PM
  #43
kyoo's Avatar
I'd literally rather shave down the +25s lol. I think the +25s will be fine with a pull, should do it anyway though
Old Nov 17, 2016, 04:11 PM
  #44
No, you can't do that. The wheels has the same thickness from the lug nut taper to the mounting surface, regardless of offset. If you shave the wheel down, you run the risk of the lug nuts pulling through the wheel.
Old Nov 21, 2016, 08:33 PM
  #45
kyoo's Avatar
have any of you guys seen something like this
http://www.ft86club.com/forums/showthread.php?p=2333175
to use since the bore on these wheels is 73mm?
Quick Reply: WedsSport TC105n 17x9 +35
