NO ABS brake bias
Old May 30, 2013, 11:21 AM
hans512's Avatar
NO ABS brake bias
Hello, im still worried with my evo9, the car doesnt brake, i have changed up everything including rotors, pads, brake lines, MC, non of them make the car stop better.
now im aiming to the ABS module, because the car does not have a proportioning valve, i was told that the ABS module control brake bias.
is that correct? under hard braking it feels that the front end doesnt receive as much pressure that the rears, resulting in rear wheel locking.
BTW, is it a good idea disableing ABS and run a aftermarket proportioning valve?
i ran that setup in a 2002 sti, brakes are great, the DCCD is not adjustable.
any opinions?
Old May 30, 2013, 12:02 PM
03whitegsr's Avatar
The ABS module is also an electornic proportioning valve. It will out perform a manual setup.
If the rears are locking up and the ABS isn't kicking on, it's because the ABS isn't working properly.
Old May 30, 2013, 12:41 PM
hans512's Avatar
thanks, clear my doubt about abs proportioning.
is there any posibilites of a sticked valve inside the module?
cheers
Old May 30, 2013, 02:11 PM
03whitegsr's Avatar
It has diagnostics built into the module. I imagine it would catch any issue like that and throw the brake light to let you know there is an issue.
Old May 30, 2013, 04:18 PM
WRC-LVR's Avatar
Should be able to diagnose if you take it to dealer or someone who has the MUT3 tool.. I read somewhere there re specific codes corresponding to various issues.
Just a long shot but check to see if the ABS fuses are there and in good shape, nothing blown.
Lastly, by any chance are you running a different pad set up front rear with the better bite pads on the rear? if you are, use a pad with less bite on the rear..
Old May 30, 2013, 05:10 PM
heel2toe's Avatar
This was my first thought.
The abs is pretty smart so i would imagine you would see a code...
xceler8rob
Feb 29, 2016 09:58 AM
Foxman92
Jan 10, 2016 06:49 PM
NewEvolutionIX
10
Dec 10, 2015 12:59 PM
badev0
Nov 13, 2015 05:51 PM
X91EVO
Apr 18, 2013 06:16 PM
Quick Reply: NO ABS brake bias
