Whiteline sway bar bushings-- squeaky?
Old Sep 28, 2013, 12:21 PM
meckert's Avatar
Will be putting on a whiteline frt sway bar on an EVO VIII-- how noisy are their poly bushings? I ask as a I hate squeaky bushings and have a set of blk energy suspension bushings as well, sized and ready to go-- they are Blk and a lot less noisy then their std bushings ( red). The ES bushings also seem to be harder btw. Pls advise and thx.
Old Oct 7, 2013, 04:16 AM
Fireescape's Avatar
I've got a rear Whiteline swaybar on my car with the supplied yellow bushings. Has been on for maybe 12 months and I haven't heard a single squeek or noise of any form from it. Got a front to put on soon and I will be using the supplied Whiteline bushings on it. Just use the supplied grease, or equivalent, and you will be right.
Old Oct 7, 2013, 04:10 PM
meckert's Avatar
Thanks Brother, good to know someone else has these kinds of concerns. I opted for the ES bushings I had and if for some reason they dont stand up, I will sub in the WL bushings since the hard part is already done. I just dont like the twisting sound of suspension bushings and so far so good on the other bushings I have done. No need to compromise. Again Thx. BTW, you will like the frt bar actually not as much of a difference as the rear bar until you pushing it at speed--other wise hard to tell-- I dont feel the 38% stiffness over stock at lower speeds in corners. FYI.
s2h757
Apr 6, 2017 06:30 AM
Don'tNeed6th
Aug 14, 2016 01:26 AM
wjamyers
11
Sep 17, 2015 11:05 PM
rawkus
Jul 1, 2015 06:51 AM
Quick Reply: Whiteline sway bar bushings-- squeaky?
