Very Mushy Brake Pedal (Bleed Twice Now)
A few weeks ago I was driving and my brake pedal went from normal to down to the floor in 10 stops. I have no idea why. Stopped the car and Reservoir was empty. Filled it up (was close to a WalMart) and limped the car home. I had pressure, but it would require 75% pedal travel to get decent brake contact.
Fast forward. Since then I've replaced the crush washers on the front lines (SS lines) with new, copper ones to protect against corrosion. I've bleed the whole system twice with a buddy on two separate occations. Followed this both times (http://www.joe250.com/cars/evo8/brak...ebleeding.html) and have bleed brakes many times before.
I am still not getting pressure in my brake pedal. Reservoir is full and when I bleed the calipers, all that comes out is pure liquid. It's no better than it was before the bleedings. Pads have ~.375" of meat left. Driven it around the block and still need 75% pedal movement to get decent bite. If I pump the pedal while the car is off, it firms up right away. That gave me false hopes.
I feel like there has to be air in there somewhere. Master cylinder need bleed? Is there a good how-to on this? Also it's worth noting that the driver's side front, inside bleeder valve stripped so I wasn't able to bleed that one at all. But the pedal is no better than it was before so I don't think that's the main culprit.
Suggestions
Suggestions
I am also concerned about that. I think one of the washers that sits between the brake line bolt and spherical fitting corroded, because as my buddy and I were bleeding the brakes we noticed fluid spraying out of that location. However, we didn’t notice that until we had done three of the calipers already. So maybe it was a slow leak that turned into a big one… I dunno. That’s why I replaced them with new, copper washers and it stopped the spraying.
first things first......did you find your initial brake fluid leak? fix that, otherwise you'll continue to have issues.
if your evo has abs, there is a lot of air in the abs manifold.
buy lots of brake fluid....buy yourself a motive brake bleeder & crack each line going into the abs manifold, you will see / find air.
GL
GL
The leak is gone, but the pedal is still mushy. There is definitely air in the system still.
That's what I am thinking next. Bought a MC bleeder kit today.
Where is the ABS manifold?
Thanks,
GL
GL
Thanks,
Well, got the problem fixed. Ended up bleeding the system two more times, which made for five total. I guess there was a bubble somewhere that was being extra stubborn. Really didn’t want to do the MC unless I really had to so decided just to try a couple more bleedings. Pedal felt really good after two more cycles so I took it out to test it (just around my block). Still felt really good and was even able to get the ABS to kick so I think all is good. Drove it to work today.
Thanks for all your suggestions.
05ah8james
21
Jul 31, 2013 03:56 PM
Montu
165
Jul 26, 2013 11:23 AM
matrho2792
19
Feb 25, 2013 09:03 AM
