Synthetic PSRS Free and Easy
#32
This tells me you don't understand what the purpose of the rating is. The purpose of using the correct "weight" is to ensure that you have the optimal viscosity of oil at startup and operating temperature for the environmental conditions that the engine is doing to work in. If you mix two different ratings all that means is that in the wrong environmental conditions some of your oil is either going to be too thick or too thin. Some one is going to come back and say "hey I've done that for years and it didn't hurt anything" well depending on the environment the car is in if the ratings of both oils work great in those conditions of course it won't matter. Put it in an environment where one of those ratings has that oil too thick or thin and it's going to be another story. This isn't mixing differing octanes here.
You don't solve a pickup problem with an oil's rating, you solve it with some kind of sump or baffling around the pickup. This of course also ignores the fact that if this worked how you expected it to work and the "heavier" oil was around the pickup what happens when that heavier oil makes its way to the head or the cams?
You sir should look up the definition of sarcasm in the dictionary. And while you are at it, you should look up satire as well.
#37
LOL. Got trolled by the guy trolling the troll....
ILoveAWD
Pacific Northwest
Jun 16, 2012 10:01 AM
imamamasboy
Toronto Lancer Club
Mar 31, 2009 06:25 PM
