Need help
Well, there is no perfect size. Each wheel has its own combination of offset & spoke design & tire fitment
But in my opinion this range may be Ok w/out modifying the rear fender
18x8.5 to 18x9.5 w/an offset of +35 to +38 running a 255/35/18 tire
But its also my opinion that you should consider modifying the rear fenders, otherwise just run the stock wheel 17x8 +38
The stock EVO hub bore is 67.1. You will need to run the preferred alum hub rings vs the plastic. We all run the rings so its normal & needed!
What about + 30 offset ?
The size is 18×8.5 or 18×9.5 or 18×10.5
Which is better size for evo 8 with out any change in fender?
Do yourself a favor & search this thread & read what others are running. This will help you understand the common specs we are using
10.5 is very difficult to fit. Not for the faint of heart. 9.5 more prone to rear fender work but very popular. 8.5 much easier to fit w/out rear fender work
https://www.evolutionm.net/forums/ev...el-thread.html
18x9.5 +35
18X9.5 +20
are this sizes fit evo 8 with out any fender work?
sorry MinusPrevious for a lot of quez
18X9.5 +20
Forget about the +20 until youre ready for some real rear fender work
