Enki RS05RR fitment question
Im looking to run a set of Enkei RS05RR'S 18x9.5 +22mm with a 245 tire. Im curious if anyone else has ran them. I have no issues rolling the rear fenders and pushing out the front fenders, but that is the extent of the body work that i want to do.
The +22 puts you on the rev limiter when it comes to offsets. Its very doable but the rear fender will need a bit more massaging on top of the roll
The tire choice is helping the situation & would consider running a 245/40 vs the 245/35. The 40 series is closer to the stock circum
IMO, the rears will need a bit of a pull & the bumper bolt relocate maybe needed running stockish camber
The fronts will work but some liner rub is likely at lock positions
