New XXR 527 size 18x8
Will these new xxr 527 18x8 with +42 offset fit an evo 8 with no modifications?
http://www.nlmotoring.com/XXR-527-Wh.../52787102n.htm
Yes. I searched but everyone seems to run the 8.75in wide rim.
Yes. I know there are a ton of XXR threads.
Yes. I know they are cheap rims and I get what I pay for.
Thank you in advance.
Well before I answer your question, the Stock Enkei's on Evo 8's are a +38 offset.
You want to go to a +42 offset which no offense doesn't make any sense unless you don't understand how offset works.
The 18x8 rim diameter itself will fit the car but I wouldn't waste my money on the +42 offset.
Try finding rims with a +30 or +35 offset this will be a clean look with minimum fender work to make the wheels fit. Hope that helps
That will require major fender work, not just a fender roll but a pull as well. Like I said try finding some with an offset of +30 or +35.
