Track day street tire options
Old Jul 11, 2016, 01:44 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by mouseIX
That is really good to hear!
I usually buy from TireRack (dealer discount), but they don't sell Nitto's. Where is everyone sourcing their NT01's? I see they don't make them in my current size 245/40r17, Anyone run 255's on the stock wheel?
Discount Tire. Also check Discount Tire Direct on eBay as sometimes you can get SERIOUS deals on them there. Currently they have 5-10% off.
The NT01's run very wide.
Here are my 275/35/18's on a 10.5 wheel
Old Jul 11, 2016, 03:23 PM
kaj
kaj's Avatar
FWIW I run 255s on a 9.5 wheel. The Hankooks fit pretty well and the Bridgestones look like they are stretching too much (I like a straight sidewall). My point being check how each tire fits to pick the right width, as the guys above have mentioned.
A slight stretch is okay (I actually do appreciate the response I have) but you don't want to go too wide unless you are an autocross-only guy.
Sounds like I need a 255 NT-01!!
Old Jul 11, 2016, 03:29 PM
RazorLab's Avatar
The NT01's are better if fitted without bulge and slight amount of stretch, if they are too wide on the wheel they feel a bit vague and mushy.
If they are fitted like my example above, they feel MUCH better.
Old Jul 11, 2016, 03:44 PM
kaj
kaj's Avatar
Good to know. That's how the R-S3 was. So perhaps a 245 NT-01. Yay. They are cheaper LOL
Old Jul 12, 2016, 08:02 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
My NT01's def feel better on the 10" wide wheel than they did on the 9.5.
Old Jul 12, 2016, 10:25 AM
mouseIX's Avatar
Hmmm. I may wait on NT01's for when I go 18" wheels. Thanks for all the input. As a side note I've been checking on used Conti series takeoffs, if I go that route I will post up on everything. For now with my tirerack connection I'm leaning towards the ZII SS.
Old Jul 12, 2016, 10:36 AM
kaj
kaj's Avatar
I was looking at the take offs too, at one point. I just figured they are probably heat cycled out. I bought a used set once and they were hard as rocks, so I'm gun shy LOL. Cheap, though.
Old Aug 1, 2016, 01:26 PM
rk7
rk7's Avatar
I second the NT01's, but yeah people seem to have better luck running them on a 10" than a 9.5" for whatever reason. They still have been go to me, though, so can't complain after two events.
Old Sep 14, 2016, 07:27 AM
ddlopresti's Avatar
I run 265 35 18 RS3 on my evo x gsr with 500WHP, Ohlins and GiroDisc 2pc rotors with carbotech xp10 pads and I got about 8000 street spirited miles including trips to the Dragon etc and 2 track days (3 20 min session each day with some additional practice lapping) out of them. Had plenty of tread depth left but the latest day at pocono raceway with mostly high speed right hand turns and braking the tire is looking pretty dead on my left side. I was pleased with the performance as long as I kept them below 33psi, i would start the sessions out at 29 and it would end around 33.
I liked the performance but i wish i could find something that would stand up to the heat better, maybe get a dedicated set of R888 for track only.
Old Sep 14, 2016, 04:07 PM
e_kobz's Avatar
Avoid R888, they get super greasy and slick real quick. Go NT01
Old Sep 14, 2016, 05:18 PM
RazorLab's Avatar
If you are looking for something that can stand up to heat better, avoid the R888 tires.
As stated above, go NT01.
Old Jan 4, 2017, 07:14 PM
Matz's Avatar
NT01s are great but the Dunlop Z2 SS will be a better street tire, especially in any moisture.
The NT01s are also way louder than Z2 SS if you can believe it.
You can hear mine here, they sound like a damn TIE fighter:
Thunderhill back straight - YouTube
Forget the tires, damn, those brakes!!!
Old Jan 11, 2017, 07:24 AM
LV///R's Avatar
That's interesting to me.
All along I've been told and read on various forums that the NT01 and R888 compounds were exactly the same, but just a different tread pattern. I'm sure there's no way to truly confirm this, however.
I've tracked my supra with R888's, but only autox'd an evo on NT01's so I can't confirm or deny this. Just had to comment.
Old Jan 11, 2017, 09:56 AM
They're definitely different. R888 do not heat cycle well. NT01's heat cycle great until they cord. R888's are also easier to overheat.
Old Jan 11, 2017, 10:21 PM
Olegator's Avatar
I've ran RE71R tires in 245 size at three track events so far and have not found them getting greasy. It's east to mistake tires getting greasy for tires being overheated due to pushing them too much in improper way. What I'm talking about is overheating front tires only.
The goal for the driver is to distribute load on tires as evenly as possible. Therefore keeping the tire temps in check. If the car is pushed in such a way that only the fronts get too hot (usually due to improper apexing the corner), then the car will feel mushy and understeery.
That's only my educated opinion though.
Quick Reply: Track day street tire options
