Adjustable Rear *UPPER* Control Arm
hey guys so i currently run a set of adjustable LcAs and i need some top camber adjustment to pull the top of the wheel in, instead of pushing the bottom out
cant find anything anywhere was wondering if there was such an item or not
To me it seems pointless to do this. Just decrease the camber back to oem spec using the lower rear control arm. Just pull it in.
Racefab in NZ makes an adjustable upper rear control arm where the top ball joint is adjustable on their set. You must have a weird clearance issue with those adjustable lower control arms.
neogeo64
Jun 19, 2013 06:30 AM
RunThat
23
Mar 29, 2011 09:48 AM
bluej20
Apr 25, 2010 08:36 PM
goforwand
May 22, 2009 01:46 PM
