Low 3582HTA Numbers :(
Healthy 3582HTA Numbers :)
I got the car tuned last Saturday and the numbers to me seem low, but I guess the only true dyno is the track. The car made 460whp @ 25psi on 93pump. This time around I added BC 272 Cams and meth and upped the boost from 25 to 28psi and made 375 whp on a mustang dyno. I know Mustang Dyno's typically read low, but this is extremely low.
Something doesn't seem right with that, even with the difference in dyno's you lost 85whp after doing cams and meth. If you were on that same dynojet I'd expect to see 530whp-ish with the cams and meth at 28psi. Are you sure you aren't running out of fuel on that single walbro?
From the GTR forums, a stock GTR will make around 360- 380 whp on Akuma's dyno. Stock GTRs make 470- 480 whp stock on a dynojet so your numbers seem about right. I wouldn't worry about it until you take it down the track and see what mph you make.
Brian Crower...??
Young grasshopper - Brian Crower couldnt grind a cam straight to save his life. Evo8/9 cams have been off more then 6 degs out of the box. What makes you think they magically made them better for the X. Ya bought cheap cams - infact the cheapest made, with the worst quality control in the market. These results do not surprise me at all. If you want performance out of your X buy Cosworths, or GSC's... If you want to get nice low numbers - buy from BC.
Just wanted to try a new shop and they are a little closer to me. Ivey did a fantastic job so my decision to go somewhere else had nothing to do with unsatisfied work.
