Injen Technology EVO1800 for 2008-15 Lancer EVO X
Injen is proud to be introducing the all new Evolution cold air intake system for the 2008-2015LANCER EVO X This intake has been designed using the some of the most up-to-date engineering tools and techniques to produce a top notch kit. This intake system is on a whole new level, All the way down to ITS premium hardware, Injen has put it all out there to give you, the customer one of the most killer intakes available.
Roto-molded Housings:
The housings sports the ClearVue sight window allowing for a easy visual inspection of the air filter when every you pop the hood.
Roto-molded Intake Tubes:
This Evolution Air Intake System uses a couple of custom designed and dyno-tuned, intake tubes to produces huge power gains while retaining a clean and quality fit.
SuperNano-Web Dry Air Filters:
The SuperNano-Web Dry air filter is one of the largest filters possible to increase air volume while keeping the installation process simple.
Quality Hardware:
Stainless Steel Band Clamps with inner protective liner and reinforced automotive grade silicone couplers are used to provide the most secure installation available.
Hassle-Free Installation:
Evolution cold air intakes have been carefully designed to use fewer parts to provide the end user with one of the quickest and simplest installation available today.
Dyno Results:
After hours of design and dyno testing This Evolution Air Intake system was putting down 35 additional horsepower and 37 lbs. of torque.
For more information on this and other Injen Technology cold air intake systems please visit our website: www.injen.com
Quality Hardware:
Dyno Results:
evo 1768 (Aug 8, 2016)
https://www.evolutionm.net/forums/ev...ive-tuned.html
Very happy with the intake. If you are not a fan of BOV psst sounds this one is for you. super quite.
injentechnology
Lancer Aftermarket Forced Induction Tech
Feb 20, 2017 03:55 PM
injentechnology
Jan 16, 2017 02:00 PM
injentechnology
Sep 9, 2016 11:11 AM
Ray@INJEN
50
Aug 3, 2004 11:36 AM
