EnglishRacing Drag X 1199whp 8385 Gen 2 59psi
Old Feb 10, 2017, 10:04 AM
  #31
JohnBradley's Avatar
The EGT is really high on a stock port 4B11, the intake isnt the issue as it will flow more than a 4G63. The 29mm exhaust valve and port that is 2/3s the size elevates EGT by 250* on average. It flows by virtue of force but bottlenecks create problems. The main thing we get when we port them is reduced backpressure and EGT. There is definitely power in porting the exhaust as well though, we have found 60whp overall.
Old Feb 10, 2017, 11:16 AM
  #32
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Originally Posted by razorlab
Can you elaborate? This car is making 1200whp with a stock port head...
I keep seeing you say this but there are a plethora of 700whp+ 4b11's with non-ported heads.
I meant turbo for turbo. To extract the full potential from a turbo, the 4b11 works better with a ported head. See below in regard to lower backpressure and EGT, by a lot.
Old Feb 10, 2017, 11:30 AM
  #33
The other thing to keep in mind is it made 4whp more than a full port 4g63 with a turbo that is 11mm bigger. This car should have made over 1300 with a ported head and the 8385. 7285 to 7285, Drag X vs Drag 8 the stock head is down around 100whp, different motors to be sure but it shows where the stock head is really at in comparison.
black E (Feb 16, 2017)
Old Feb 10, 2017, 02:36 PM
  #34
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Good info, thanks for sharing!
Old Feb 14, 2017, 01:38 PM
  #35
NotThisFool's Avatar
Oh dang 64 psi at 10,300 rpm.
Really impressive!
all custom work and all. Congrats on a great build.
Old Feb 21, 2017, 03:38 AM
  #36
HaterMagnet's Avatar
so whens the full boost pass coming?
Old Feb 21, 2017, 05:23 PM
  #37
When we have the M150 in it and 8 injectors on methanol. It will get to real boost and timing then.
M150 has a base calibration at this point based on my X, most of the CAN sniffing has been done, etc. We have to build a new harness and then wire the extra 4 injectors. It is coming soon though
Old Mar 9, 2017, 12:10 PM
  #38
linuxjm's Avatar
Any video of the dyno pull or car in action???
Should be looking at 7 second pass at track
Old Mar 10, 2017, 10:31 AM
  #39
1/2 mile and some drag racing.
Dyno video and walk around at PRI
http://www.revvedmag.com/videos/on-t...x-at-pri-2016/
Some faster passes at the track, drag racing.
http://www.dailymotion.com/video/x4cvsz0
I will look for more.
Old Mar 11, 2017, 10:42 PM
  #40
2winscroll's Avatar
Nice work! You guys R top notch! What a/r do run on a turbo that large? Just curious 500hp @ 6500 seems like it's not as much lag as you would expect from a turbo that large.
Old Mar 23, 2017, 04:59 PM
  #41
Old Mar 24, 2017, 11:34 AM
  #42
ChipperEvo's Avatar
I just watched the 1320vid on this.
Congrats!
JohnBradley (Mar 27, 2017)
Old Mar 24, 2017, 11:40 AM
  #43
Pal215's Avatar
Wow! Excellent job guys, that thing is a monster.
-pal215
Old Mar 25, 2017, 08:52 AM
  #44
NY Black momba's Avatar
i hope you can get this to go 7s
JohnBradley
Oct 9, 2017 05:29 PM
JohnBradley
Evo X Dyno Results
75
Sep 28, 2015 01:01 PM
DynoFlash
34
Mar 14, 2005 08:52 PM
Quick Reply: EnglishRacing Drag X 1199whp 8385 Gen 2 59psi
