Moore Automotive 2008 Evo X GSR - FP Super 99 - 1005whp/652wtq
Old Dec 18, 2016, 07:49 PM
Moore Auto's Avatar
I did this a few moths ago but haven't had much time to post it up (or any of our recent projects lately). This past years iteration of my X has had some positive and negative results. Positive being that it made great power and feels amazing on the street. Negative is that the way everything was designed, I wanted to minimize lag as much as possible on the Super 99, guess I did that a little too well, lol. I actually ended up spooling up the turbo too fast and putting into horrible surge that would shake the car and slow it down when shifting into 4th and especially 5th. You can see on the graph it's spooling around 4000rpm and has 20psi by 4600, pretty crazy for a 72mm turbo, lol. Even crazier is that it was spooling faster than that, this is the slowest I could get it to spool. Already working on the fixes for all this over the winter, so I should actually be able to get it down the track as fast as it should be, lol.
Moore Automotive 2.2L Stroker (Manley crank, Turbo Tuff rods, custom Wiseco stroker pistons)
Headgames ported head
Custom cams
Cometic MLX headgasket
ARP 625+ head studs
SSP Titan intake manifold
Boomba 75mm throttle body
Moore Automotive custom sidewinder turbo kit
FP Super 99 turbo, v-band 1.03 turbine housing
ETS 5" Intercooler
ARE/Moore Automotive dry sump oiling setup
Electric Waterpump
SparkTech ignition system
Moore Automotive big fuel system with MagnaFuel 750 fuel pump and ID2000 injectors
4" aluminum exhaust
Probably some stuff I'm forgetting, lol
46psi on pump E85
Andrew Ferrer (Feb 1, 2017)
Old Dec 20, 2016, 05:46 AM
black E's Avatar
Great power!
But why the weird powerband? You had to do that so it wouldn't surge?
Old Dec 20, 2016, 07:57 AM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
Originally Posted by black E
Great power!
I would say so. Torque curve follows the boost curve.
Old Dec 20, 2016, 10:11 PM
lonestarr20's Avatar
Ohh la la
Old Jan 26, 2017, 01:21 PM
Moore Auto's Avatar
Great power!
Yeah, since my setup spooled the Super 99 so fast it threw it into pretty bad surge. I had to go down in spring pressure in the wastegate and tune the curve like that to keep out of surge. Although it wasn't quite enough, as it would still do it going into 4th and really bad going into 5th gear. So going back to 2.0L to slow spool and rev it out farther.
~Chris
Old Sep 10, 2020, 02:19 AM
Chodezilla12's Avatar
Originally Posted by moore auto
i did this a few moths ago but haven't had much time to post it up (or any of our recent projects lately). This past years iteration of my x has had some positive and negative results. Positive being that it made great power and feels amazing on the street. Negative is that the way everything was designed, i wanted to minimize lag as much as possible on the super 99, guess i did that a little too well, lol. I actually ended up spooling up the turbo too fast and putting into horrible surge that would shake the car and slow it down when shifting into 4th and especially 5th. You can see on the graph it's spooling around 4000rpm and has 20psi by 4600, pretty crazy for a 72mm turbo, lol. Even crazier is that it was spooling faster than that, this is the slowest i could get it to spool. Already working on the fixes for all this over the winter, so i should actually be able to get it down the track as fast as it should be, lol.
Moore automotive 2.2l stroker (manley crank, turbo tuff rods, custom wiseco stroker pistons)
headgames ported head
custom cams
cometic mlx headgasket
arp 625+ head studs
ssp titan intake manifold
boomba 75mm throttle body
moore automotive custom sidewinder turbo kit
fp super 99 turbo, v-band 1.03 turbine housing
ets 5" intercooler
are/moore automotive dry sump oiling setup
electric waterpump
sparktech ignition system
moore automotive big fuel system with magnafuel 750 fuel pump and id2000 injectors
4" aluminum exhaust
probably some stuff i'm forgetting, lol
46psi on pump e85
https://youtu.be/2wflktwu-0w
Attachment 263013
Attachment 263014
Attachment 263015
what are the wheel specs??
Old Sep 11, 2020, 09:00 PM
robos4's Avatar
EDIT, sorry I realised this is an old post.. What ever happened?
Very nice!!! Love the long power curve and 2.0ltr should make a nice 9,000rpm peak result.
Would you not consider keeping the current motor and increase the A/R on the rear of your turbo?
Vinay1789
41
Feb 18, 2019 12:39 PM
lonniee23
17
Dec 14, 2016 08:58 AM
Sikilla
Oct 16, 2015 01:43 PM
Moore Auto
Evo X Dyno Results
56
Jun 10, 2014 08:27 AM
Moore Auto
Evo X Dyno Results
20
Oct 24, 2013 06:17 PM
Quick Reply: Moore Automotive 2008 Evo X GSR - FP Super 99 - 1005whp/652wtq
