Stock Fosgate Amp + aftermarket radio = WORKS!!!
so just curious, how is this system holding up sound wise. Compareable to stock. Also what wire in the harness did you tap for the VSS wire for the navigation. Im about to do this and it would be a huge help
also it looks like you went yellow from the new harness to the red white of the stock harness. Is that what you meant to say. Are the wire colors in the car flopped compared to the aftermarket radio.
thansk
thansk
k, what do you mean by the cound field? Do you mean on the stock stereo the pop, rock, dance selection? Also i know you left the bass and trebel; and mid at 0 on the stock but did you turn the punch setting up at all on the stock or leave that 0 too.
Are you still able to get the same bass out of the system now.
Just want to make sure this is the right decision for us, for now
Tahnsk though
could you confirm which soundfield needs to be turned off, stock radio or pioneer. Also are the wires opposite in the car, i think i red someonewhere that in the car the red is the ignition and yellow is constant, I just want to confirm because you have yours stated as the opposite of that.
please help.
Trying to install tomorrow and my volt mete is not working.
please help.
By soundfield I mean the "rock", "jass", "classical", etc and the settings for "hall", "stadium" and "stage".
That’s good that you found the VSS wire, please post that info some were for others that may not know.
Its been awhile now since I installed that radio but I remember my post being correct about the wire colors and no one has corrected me yet.
The fuse for the radio is far bigger than needed and will be more than enough for the old radio and the new radio. The new radio will draw much less than 1amp @12VDC without using the on board 50x4 amp. The factory old radio will only draw 250mA @12VDC or so (0.25amps) The radio wires are 18awg and can handle 10amps but my rule of thumb is to keep it less than 6amps on 18awg wire or it can get warm.
awesome thanks.
as for the vss, yeah ill post it here and then see if i can get a post stickied but it is the white wire blue tracer on the 20 pin connector that goes into the stock radio
