remote start on Evo X??
Registered User
Has anybody installed a remote start on the EVO X? If so which one did you use?
Are there any remote start securit kits that can work with all of the keyless funtions on my MR? (keyless entry, start, trunk)
Looking to put one on my car, however I want to keep my SMART key working while vehicle is remote started.
But it should be no issue if you want to use an aftermarket remote start/keyless/trunk. All these functions should be able to be integrated in with the new system. All you should need is a bypass that your key gets installed into because it has an immobilizer built in.
I peronally like DEI products (Viper, Python...)
I know that in our area some of the local kids that do installs will do side work to 'practice'. Some shops let the installers even use their bay's so they have all the right tools. Perhaps check around and see if you can find a kid in your area? I paid 100 to have my compustar installed.
i'm an mecp certified master and i can tell you right now compustar is crap. anything directed electronics is leading in the industry. go viper. you're going to need an ign bypass for any lancer since they've all got rf keys. you can bypass it with something as easy as a 556u or as complicated and most reliable as i have it with a dlpk and rflmit3. ask me any questions because you've never seen a car like mine. it talks to me when i do anything
you'll see mine when everything i'm doing to it is done. promise as for fastkey yes it will work with the 556u but you lose one of them. downside is if you forget to lock your car then somoene can drive off in it. i've done a few of the fastkeys before even and they're kinda dumb to tell you the truth. the ones for toyota and mercedes are very similar and equally rtarded. anyways i've still managed to keep the 30s relock in there on one of the gts's i've done. and your face is full of it. you'll see the pics/vids when i'm all finished with everything like i said
Also, there has been some FAST keys done using the PKU-MITSU bypass....which does not require that you lose ANY keys and there is no threat of your "key" in the car staying powered.
Adam
