A little more bump.
I don't think you will be able to fit a 12" sub in the factory box. I've had it apart and just don't think there is the room. I went with a new 10" sub after reinforcing the factory box. I put in a RF P3 shallow sub and added a new amp to power it better.
It can be done, just check the impedance on the stock woofer to see what kind of load you'll be presenting it. IF the X is like the older ones, you'll have to cut the end of the wire osf as it probably has a unique coupler to attach to the sub. But yeah, you'll need a new enclosure.
If the stock amp is that weak, I wouldn't waste time putting a bigger woofer on it, it probably won't hit much harder at all, if any. I don't think I would try putting a bigger amp on the stock woofer, although that would be the better solution. I'd wait until I had enough money to replace both the amp and sub. The highs will probably sound better on a bigger nicer amp, so you can probably leave them alone for a bit.
Like GPTourer said, I'd wait until you can upgrade amp AND sub at the same time, and maybe even front speakers too.
Hey! Before RF came along, Mitsus used that same "junk" from Infinity. I'm still using the stock Infinity highs in my Evo with a Memphis amp and I removed the Infinity sub and have a JL amp on a (aftermarket) RF Sub. The highs sound okay, enough that I want to upgrade them with a nice set of Focals ($$$) and not mess around with anything in between as far as money or quality is concerned.
I'm tempted to get a good 5 channel amp - or maybe a good 4 channel and a mono amp dedicated to the sub. Could always fit the second amp under the passenger seat.
Come to think of it, there is few select cars, like the Mark Levinson system and few other stock systems I believe are pretty good.
Some really high end speaker are made out of paper. Just depends on the paper. But yeah, stock speakers are usually not going to tolerate much more power then they're given. That's why I say don't bother bumping up the power on the stock woofer.
Dem1K
12
Jun 27, 2002 02:54 PM
