Radio Wiring Pins/Connector
Old Mar 10, 2014, 04:24 PM
gman_CZ4A's Avatar
Hello all, I have a question for you guys. Does anyone know what type of pins going into the connector for the radio is. I need a few of them to do some rewiring. Appreciate any help, thanks.
I'm also looking to see if anyone has the 18 pin connector for the radio. I messed it up trying to remove the old pins. I have a Mitsu part number but my only search results are in Japanese - MU80159
Attached Thumbnails Radio Wiring Pins/Connector-img_20140310_184314_708.jpg   Radio Wiring Pins/Connector-img_20140310_183822_761.jpg
Old Mar 11, 2014, 11:27 AM
ikt
ikt's Avatar
take the plug to radioshack or just hardwire it. Also, radio shack sells blank plugs where you can make your own harnesses
Old Mar 11, 2014, 02:43 PM
gman_CZ4A's Avatar
I would if I could, but I need the connector, as it plugs into the radio directly. I've also found a website that lists it for sale. I would buy it but Im not sure how. Best bet would be to probably go to a pick n pull and cut one out of a wrecked car. Sadly I don't live anywhere close to one.
Old Mar 11, 2014, 02:48 PM
ikt
ikt's Avatar
radioshack sells just a standard wire pin kit too, it's pretty universal. And cheap.
Old Mar 26, 2014, 03:02 PM
gman_CZ4A's Avatar
Well I found out the terminals and connector I'm looking for.
The housing is Sumitomo #6098-3019, TS Series, 1.0mm tab.
The female terminal is Sumitomo #8100-2730, TS Series, 0.3-0.5mm2.
The terminals I should be able to source easy enough, but the housing is going to be the problem. Most places require a minimum order of 5000 or so.
If ANYONE out there has this 18 pin connector that they just cut off their harness to wire in their aftermarket stereo, please let me know. I know most people just buy an adapter harness, but some do splice their headunits in.
Old Apr 1, 2014, 11:01 AM
ikt
ikt's Avatar
Metra makes harness adapters that fit into the OEM harnesses for $8, would that would? You could just re-pin it
Old Oct 1, 2015, 07:25 AM
kilroywzhere's Avatar
What is the pin configuration for the plug? does anyone have a pin out picture? I can't find the right one on google.
Old Apr 30, 2023, 05:53 PM
ghost911's Avatar
I need 8 of these and ya only can find the Japanes site, hopefully you are active and found some on Amazon.
sameeeer45
33
Sep 22, 2017 04:05 AM
Anubis7
Apr 11, 2017 05:05 AM
emerica243
Outlander Sport
Jan 9, 2016 12:37 PM
glenn63
Oct 8, 2015 08:26 AM
sicily12341
Oct 1, 2015 07:22 AM
Quick Reply: Radio Wiring Pins/Connector
