calling all electrical gurus, help needed
Old Mar 24, 2015, 10:27 PM
robyn402's Avatar
alright everyone need some help
So i'll give you the coles notes of the issue;
1) did a wire tuck which included shorting wires etc, all connections were made properly wire colour coding/solder/heat shrink
2) hooked up battery backwards
3) blew 120 amp fuseable link in positive terminal and killed old genesis battery
4) replaced fuseable link assembly
5) replaced battery
6) car turned assesory/on position battery reads 12.X volts via voltage gauage and Cobb AP, apon starting car voltage jumps to 15.6 volts and stays constant, charging system service required light comes on (obviously)
7) assumed alternator regulator failure, bench test alternator, alternator output = 14.4 volts
8) check engine wire harness alternator regulator wiring, 3 wires lead from regulator connector to ECM connector, 0 ohms resistance on all 3
a 4th wire goes from regulator connector to a 7.5amp fuse in the engine fuse box (not blown) then to fuseable link #36 (on positive terminal also not blown) couldn't get a resistance reading on this line (might just be the size of the probe)
9) no observed blown fuses in engine fuse box
auto electric shop suggested possibly a sence line may not be working... i'm all out of ideas
Old Mar 30, 2015, 02:58 PM
ikt
ikt's Avatar
the dealership has a test unit that can easily track it down for you, I've done similar.
Old Mar 30, 2015, 05:27 PM
robyn402's Avatar
Oh turns out I mixed up the voltage regulator sence line and something else when i re did the harness... All better now
Old Apr 1, 2015, 01:53 PM
hispanicpanic's Avatar
glad to hear. Electrical gremlins are my worst nightmare.
OC
Mar 31, 2016 11:43 AM
ant_BLR
12
Mar 27, 2014 02:26 PM
LetItBreath
Apr 1, 2009 10:13 PM
pltek
May 3, 2007 02:17 AM
Lancerguy'03
Feb 7, 2006 10:16 AM
Quick Reply: calling all electrical gurus, help needed
