How to upgrade to rockford fosgate system
I'm thinking about getting an Evo X and I am curious how to upgrade to the Rockford Fosgate system.
Is it plug and play with speakers and sub. Prewired? Different head unit and amp? I was thinking maybe buying some take off parts at was curious what parts would I need?
You have a few options here. The head unit can be upgraded independently, but the speakers and amp are matched so the upgrade options are -
1. keep stock radio and amp - use line level converter (like audiocontrol LC8i-you'll need something with signal summing) after stock amp to feed signal to new amp/new speakers
2. replace radio and keep all else stock - you will need dask kit, Mito-03, SWI interface, accessory cables (ipod or back up cam connection for example)
3. Rip out all factory **** and go aftermarket radio, amp, speakers, sub. Or just radio & speakers if you're trying to keep it cheap.
Shoot me a PM if you have any other questions
i'm also in the same boat i have a 08 gsr with rockford forget system i just wanna upgrade the radio with a nav and keep the speakers. so all i need is a) dash kit b)mito-03 c)swi interface? sorry to hijack the thread. what do you guys recommend? i'm old school guy and i still believe on alpine head units.
This is what you need to replace the radio.
Dash kit - http://www.scosche.com/car-audio/200...kt-dbl-din-kit
Adaptor Harness - http://axxessinterfaces.com/index.ph...roducts_id=301
Steering wheel control interface - http://www.pac-audio.com/productDeta...&CategoryID=29
Head unit choice is subjective. Alpine does still make good units, but i would argue that you get better features for cheaper with a kenwood unit. And a longer warranty (2 years vs 1 year)
The stock non-RF radio and speakers really aren't that bad. The clarity is good, and the bass is pretty good for a system without a sub-woofer. I've got a 2015 non-navi and even if I swapped in a nav-unit no way would I change out audio gear. Unless you're going to compete for something, not worth it IMO. Put that money into making her fast and sexy.
JapaneseMuscle (Jan 1, 2022)
koolzero (Aug 22, 2018)
I've got the following on order from Crutchfied:
Pioneer AVH-W4400NEX DVD Receiver
Axxess MITO-02 Amp Retention 07-Up Mitsu w/ Rockford
PAC SWI-CP2 Steering Wheel Radio Control Interface
Mitsubishi Lancer 2008-Up Kit I/DD
1 Post
Is your MITO-02 still working ok? I hope I don't have any issues. I'm not too familiar with replacing head units so I don't know what I'm getting myself into. I'm curious about disabling the VSS so I can run video while the car is in motion, did you do this with yours?
Axxess told me that worse case scenario is to remove the stock amp and replace it with an aftermarket to solve the issue.
1 Post
WTF? That's weird as hell. So there's some kind of fault happening then. Maybe its that damn MITO-02/03. That **** isn't working correctly. How often do you get cutouts? I did notice that if I did not remove the OEM bluetooth and radio box it would happen all the time. Every 5-10 seconds.
