How to install HID relay harnes on Evo X
Hey guys,
I would like to install HID relay harness & Hella Supertone relay on my Evo X, but the battery is located on the trunk. Can I just install both of them to the positive battery terminal which is located under the hood? If so can anyone explain how to connect the wires to positive battery terminal correctly?
Yes, you can use that spot if you want to use the relays. Try searching for more info. I just installed the same horns and looked here...
https://www.evolutionm.net/forums/ev...tall-easy.html
SSP Jeremy
EvoX 'For Sale' Electronics / Lighting / Audio
79
Apr 28, 2015 09:17 AM
2006GSR
Feb 11, 2014 01:04 PM
LVSBB6
Sep 23, 2013 02:29 PM
GGevoXftmfw
May 10, 2010 10:43 AM
