Calculating injector latencies w/Accesstuner RACE v.math my head hurts
Also posted in CobbForums
I'm trying to find the correct latency values for my venom 750cc injectors for tuning. Since the manufacturer could only give me one value, I tried to figure out a way to calculate the other values, and used two different, but known, sets of injector latencies from the AP itself to see if there was a pattern.
I started by taking the OTS maps for DW800+HKSPF+TBE, but i am using Venom 750cc injectors. So, I calculated the new scaling value, and edited that table. I contacted the manufacturer to get the latency times for the injectors, and all they could provide was .8-1.0 at 12v. In ATR, there are 7 latency adjustments for voltage ranges.
Is there a formula for calculating these ranges? I tried taking known latency ranges and seeing if there was a pattern to the numbers.
Using the OTS latencies, I saw that with the OEM injectors, the formula like this:
using this formula: A(x)=B where "A" is the latency for a certain voltage, "x" is a variable, and "B" is the latency value of the next highest voltage on the table. Then, B(x)=C, C(x)= D, and so on.
I used the known latency values of the OEM injectors, and found this pattern:
latency(Variable)=next latency value, ascending 4.69-18.68v
6.12(.85)=5.2
5.23(.52)=2.71
2.71(.63)=1.78
1.78(.73)=1.30
1.30(.70)=.91
.91(.71)=.65
and for the DW800, the scale follows this pattern:
6.12(.87)=5.33
5.33(.52)=2.81
2.81(.66)=1.87
1.87(.74)=1.39
1.39(.72)=1.01
1.01(.73)=.74
The variable value applied to the two different sets of injectors is within 1% of each other. So, is that pattern the universal ratio that the Fuel Table: Injector Latency values are determined in AccessTUNER Race for the Evo X? Or coincidence?
6.12(.85)=5.2
5.23(.52)=2.71
2.71(.63)=1.78
1.78(.73)=1.30
1.30(.70)=.91
.91(.71)=.65
6.12(.87)=5.33
5.33(.52)=2.81
2.81(.66)=1.87
1.87(.74)=1.39
1.39(.72)=1.01
1.01(.73)=.74
I already set the proper scaling based off the OTS maps, but the only latency specs they could give me was .8-1.0 at 12V, which was radically different than the latency already mapped. That's when i decided to take two known sets of latencies from Cobb maps, and see if i could find a pattern as to how they increase and decrease, and they both were similar.
I was also really bored at work and had plenty of time
