Help ! P2096 - cel -
Old Jan 14, 2017, 09:08 AM
  #31
.M.
.M.'s Avatar
Originally Posted by nik25j
high flow catalytic converter and for the second question i really don't know
it was tuned by JR Tuned
i went there and they just told me to run another map. which i think is my previous map (that map had no boost controller or HFC or FMIC)
When they say "run another map".... are you using a laptop? Or cobb ap? Did they give any explanation at all (as far as sensors turned on/off)?
Old Jan 14, 2017, 09:15 AM
  #32
nik25j's Avatar
run another map in the Cobb Ap, and no explanation.
i was testing or running my car 30 miutes ago and it was over boosting.
Old Jan 14, 2017, 10:05 AM
  #33
.M.
.M.'s Avatar
Gotcha. Are you running a cobb off the shelf map? Or a custom one they loaded/tuned? Are you still using the afe intake? You should take a look under the car and check for that o2 spacer.
Old Jan 14, 2017, 11:46 AM
  #34
nik25j's Avatar
im running a custom tune, i went back and they fix my tuned (ill just have to wait and test my car) an no, i have an ets intake
but next time i go im tell them to check the o2 spacer/sensor
Old May 23, 2019, 01:40 PM
  #35
KillaYayo's Avatar
Originally Posted by fostytou
If you are trying to keep it operational I'd remove the fix (if its an anti=fouler). If you are using that in combination with a bend that pulls it out of the stream it may be too far out.
Or... just disable it.
So i had the o2 sensor spacers installed on my rear o2 sensor because i kept getting a code (forgot the name) but ever since i installed it the p2096 comes on all the time. Can it be because it went from too far in to too far out?
Old Sep 11, 2022, 10:03 PM
  #36
_steezyflows's Avatar
Did you find a fix? I also added the o2 spacer and I get the same CEL here and there
Cflo23
Dec 11, 2017 11:55 AM
Sam Lau
Sep 6, 2017 01:36 AM
Ang Wen Yan
348
Jan 8, 2017 11:50 PM
Benson830
Nov 8, 2016 09:32 AM
lufu
Mar 4, 2016 08:49 AM
Quick Reply: Help ! P2096 - cel -
