Cobb AP stage2+ AEM overboosting
hi,
so today i had my perrin TBE + AEM intake installed and i noticed that in both the regular 93 octane map and the LWG map i am seeing overboost. on the drive back home, i saw spikes of about 27psi with the LWG map and i am wondering if this is normal since the map is only supposed to spiked to about 25 and then taper down.
advice? i do have a .csv log file from the ride but i really don't know how to read it
I don't know much on the tuning subject, but I thought I remember seeing that the maps were made for the stock intake/filter in mind. If you have a different intake, it would probably not perform the way you'd want.
are you running the aem map? also I talked to Cobb about the boost pill while running stage 2. Not everyone needs to remove it to meet boost targets. I would put it back in and see if boost goes back to normal. When talking to the Cobb rep I do remember him saying a very cold day could affect boost as well.
If this is the first time you got on the car after a significant weather change, ie temperature drop, its not that unusual for the car to over boost the first or first couple of times. It will make a correction. If it continues to over boost (more than 26psi) then you may want to put your pills back in, at least for the winter, and flash to a stage one map.
Likewise, if the car sits for a while after learning wgdc for load targets in the cold, then comes out when it is warm, it will likely underboost the first few times.
Print the instructions off of the Cobb website (I think they call them map notes). It will have a picture of the bcs, and where the pill goes.
You really should only remove the pill if you are not hitting the proper boost targets. Since you are overboosting, I would put it back in. The shop that removed it should be able to reinstall it. If not we have links on our map download page that show how the pill is installed and where it should go. You can see those here: http://www.accessecu.com/accessport/...Pill_Instr.pdf
Please let us know if you have any other questions!
Travis
COBB Tuning
Travis
COBB Tuning
I ask because I'm running the stock DP, AMS 300 count HFC, and Perrin CBE...and I'm not over-boosting with my Cobb Stage 2 AEM v1.07 93 octane map with the boost pill removed.
I regularly spike at 27.8 dropping to 25 then tapering to 17 at redline, no harm done with over 30kmi of abuse!
2010 MR
Oem intake
MXPII TB
RRE resonated test pipe
DW 1000cc injectors
Blaqops single fuel pump
HBSpeed pill
CA91/E85(when available)
2010 MR
Oem intake
MXPII TB
DW 1000cc injectors
HBSpeed pill
ckevoxnyc
Cobb AccessPORT
10
Jun 1, 2016 03:30 PM
