Need Help with P0037
DTC P0037: Heated 02 (rear) heater circuit low
Installed the UR Hi-Flow Cat and keep getting this error. I'm running Cobb Stage 2. Anyone know a solution? Is it safe to keep running with this error code?
btw, I plan on getting a custom tune and I assume they can remove this code for good, but in the mean time, I'm keeping my Cobb.
Thanks!
Thanks!
You are not going to like this answer, but you have to take that up with Cobb. There is nothing more we can do. They have a toggle for the rear 02. If it doesn't work for you, then they have a bug in their software.
Word on the street is that their newest patch will fix this. That patch may come out tomorrow, or it may come out in time for Christmas... you never know.
I hope they come out with a fix. I would think a lot of people would have O2 sensor issues when going HFC or TP. I'll take a look into the spacers. I dont' know how that affects the sensor because I'm still kinda noobish.
I threw the code one time at WOT for a long period of time. I cleared the code once I got home to the AP and it hasn't come back on and i've ran hard several times since. Mine is stage 2 93 octane
@HPEVOX: Yea, I tried clearing it a few times, but it always comes back
@BakaUnchi: How are you going to fix it? I heard you can use the de foulers or spacers but not sure if that will affect my tune.
I can open your map in pro tuner software and shut the Rear 02 Cels off
that usually means the rear 02 is dead, but if i change the cel stuff it may work again
worst case i can shut it off and ittl just sit there as a plug
jmoney2001
Cobb AccessPORT
Oct 6, 2016 10:28 AM
