FIC's new 1650cc high-Z injector review
I wanted to write a review on the new Fuel Injector Clinic (FIC) 1650cc high Z injectors because I feel FIC gets mixed reviews.
First of all, I got these because I was running ID 1300’s and I maxed them out at like 630whp on e75, more realistically they were maxed around 600whp because AFR’s would climb to the high 12’s at redline.
I also tried the ID 2000’s and even though I was eventually able to get them to idle and drive OK (with the help of UT_EvoX) they just don’t drive good enough for me. A lot of P0300 codes, random surging, etc.
I was pleasantly surprised that when I opened the box from FIC they included a data sheet specific to my injectors. They really included all the info you may need to dial these injectors. So based on the data sheet I made my first map for them, threw them on and the car started right up with no hiccups at all. I did have to make a few revisions to the scaling and the latencies but I honestly think that FIC had it dead on from the data sheet because I run 50psi base fuel pressure and I ended up removing fuel everywhere to get the fuel trims close.
I also did not have to mess with lowering the minimum IPW or the cranking IPW. The car starts right up in the morning, has yet to throw a P0300 and I've experienced no surging to note, very smooth overall.
All of this is with e74-75. I have not tried pump gas yet but from what I’ve experienced so far these injectors are really good and I don’t think I’ll have any issues even on pump. I’m also going to the dyno later and ill up date as to how much power I made and what IDC I ended up with so anyone can get a good idea as to how much power you could get out of these.
Ok so i was able to get to the dyno today. The fuel system in the car consists of:
-FIC 1650's high Z
-Intank Walbro 255 on stock wiring and dual voltage
-Radium surge tank w/Walbro 450 @14V
-E85 (E74-75)
-You guys know the rest, LOL
The car did 655WHP/464WTQ and the peak IDC 92% via EvoScan. Keep in mind that I ran the ID1300's to 120% IDC so if you ran the FIC 1650's to the same 120% then i think these injectors could get you to 750WHP on E.
Here's a small snap of the dyno run:
-FIC 1650's high Z
-E85 (E74-75)
Thanks for taking the to post a review, we have been getting great feedback about how these tune on both pump and ethanol and are really excited about them.
These new 1650cc injectors do utilize a stainless valve similar to all other newer generation Bosch gasoline injectors which makes them safe for use with all fuels, and resistant to corrosion when using ethanol fuels.
tephra
57
Dec 23, 2023 09:14 AM
mrfred
23
Jul 3, 2017 06:59 PM
mrfred
Dec 27, 2016 09:26 PM
FS[West]: FIC 1650 Bluemax Low-Z injectors
CDrinkH2O
May 30, 2016 07:20 AM
Nov 30, 2015 04:55 PM
