Emissions check OBD Error - help
Originally Posted by franzcars
Okay, Then there is a patch that you can enable in the tune that will show that everything is ready, were you ever able to get a rear o2?
It should be in the most updated ECuFlash definition and is under ODB inspection
Attachment 237406
I updated it this is my log now. I can't edit my cars SRF file anymore. I get this error.
Here is my log.
*******************LOG******************
[19:52:22.332] EcuFlash Version 1.44.4361
[19:52:22.332] OS Version Windows (unknown version)
[19:52:22.332] Qt Version 5.2.0
[19:52:22.348] 67 memory models read.
[19:52:22.348] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[19:52:22.739] 746 ROM metadata models scanned.
[19:52:22.739] checksum module "subarudbw" loaded.
[19:52:22.739] checksum module "subarudiesel" loaded.
[19:52:22.739] checksum module "mitsucan" loaded.
[19:52:22.739] checksum module "mitsuh8" loaded.
[19:52:22.739] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[19:52:22.739] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[19:52:22.739] using metadata XML ID read_ACD from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_ACD.xml
[19:52:22.739] flashing tool "wrx02" loaded.
[19:52:22.754] flashing tool "wrx04" loaded.
[19:52:22.754] flashing tool "sti04" loaded.
[19:52:22.754] flashing tool "sti05" loaded.
[19:52:22.770] flashing tool "mitsucan" loaded.
[19:52:22.770] flashing tool "mitsukernel" loaded.
[19:52:22.770] flashing tool "mitsukernelocp" loaded.
[19:52:22.770] flashing tool "mitsubootloader" loaded.
[19:52:22.770] flashing tool "shbootmode" loaded.
[19:52:22.770] flashing tool "shaudmode" loaded.
[19:52:22.770] flashing tool "subarucan" loaded.
[19:52:22.770] flashing tool "subarucand" loaded.
[19:52:22.770] flashing tool "subarubrz" loaded.
[19:52:22.785] flashing tool "subaruhitachi" loaded.
[19:54:17.985] opening rom file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/2008 evo emissions.srf
[19:54:18.016] no definition exists for this ROM file.
[19:56:18.055] opening rom file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/2008 evo.srf
[19:56:18.071] no definition exists for this ROM file.
[19:56:42.069] opening rom file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/52680027_2008_USDM_5MT.hex
[19:56:59.057] opening rom file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/52680024_2008_USDM_5MT.hex
[19:56:59.104] 52680024 (169 tables) inheriting evo10base (326 tables)
[19:56:59.167] 1048576 byte image read.
[19:56:59.167] mitsucan checksum module determined checksum area to be {{0x00000000-0x000fffff}}
[19:56:59.182] using metadata XML ID 52680024 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/52680024 2008 USDM Lancer Evolution X 5MT.xml
which inherits XML ID evo10base from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo10base.xml
[19:56:59.182] ---notes for evo10base---
2012/10/26 [Tactrix] Updating using multiple base file data sources including base file from Golden Evo repository.
2012/11/01 [Tactrix] Moved most non-address attributes from child files to base class. Standardized file naming. Change scalings on some code modifying tables (i.e. Mode 23 - IFMode 0x05 -> 0x23) to more strongly typed bloblist scalings.
2014/05/20 [Tactrix] Tactrix definition auto cleaned|merged w/ GoldenEvoMay2014.
---notes for 52680024---
2014/05/01 [Tactrix] Original file from Golden Evo repository. If this file is useful to you, please consider donating at http://goldenevo.com/
2014/05/01 [Tactrix] Moved most non-address attributes to evoxbase.xml base class. Standardized file naming.
2014/05/01 [Tactrix] Visually examined tables for obvious errors, but no in-car verification has been done.
***************END LOG*****************************
I figured out, before I updated, that the OBD Inspection Directory "Monitor Passed(1)/Failed(0) Read Only, Do NOT Change." all things are set to pass(0) but the directory before it "Monitor Available(1)/Not Available(0) Read Only, Do NOT Change." are all set to "0".
I assume this is my issue. I could change the value to "1" aka "available" but i cannt save the file to flash to my car. Every time I save and replace existing file its fine then I try to close EcuFLash it tells me i ve changed a file and need to save the changes and the cycle continues.
issue 1 definition for my SRF file and afterwards saving the rom SRF file...
issue 2 saving the changes...
thanks in advance.
Post up the error'd out srf file to see if the rom id is different, also make sure that it's set for the Evo x not another one. Have you updated to the newest ecuflash also?
Last, do not change that table, it's apparently a stupid way just to show the info, and If you change it, things can go bad fast. The passed should all be 0's to pass, availability should be a mix
