Cobb AP different #'s than AEM gauge
Old Nov 18, 2014, 01:09 PM
evo10fanatic33's Avatar
So I'm running Stage 2 LWG 93 with mods in my signature block and I was overboosting like crazy, like 33psi crazy. So I went to Stage 3 and it just feels heavy and sluggish. I decided to switch back to Stage 2 today and see what the AEM boost gauge said and the results have me wondering how accurate the AP really is. I wasn't logging so I don't have the graph to show you but the AP said from a 3 gear pull from 3k-6k and not foot to the floor, 29psi and 4 count knock. I watched the AEM the entire pull and it never got past 25psi. The second pull, same gear and RPM's AP 33psi and AEM made it to about 23 before quickly dropping off. I'm so confused, which is more accurate, I think AEM because it's actually connected to the boost line and AP is reading ECU. Has anyone else noticed this and what or which should I believe.
Old Dec 13, 2014, 01:00 AM
Imprezme's Avatar
yeah im getting 2 different numbers as well
Old Dec 13, 2014, 09:08 AM
cravnpup's Avatar
The ECU gets boost from the MAP sensor. It's more likely that there are leaks in the line to your boost gauge. You are running stage 2 with a 3-port? You should run the stage 3 maps.
Old Dec 14, 2014, 04:25 AM
Imprezme's Avatar
Just checked everything, everything looks good but im still getting different numbers.
Old Dec 14, 2014, 04:58 AM
Sharkbite2000's Avatar
AEM stuff is most of the time is dead on when it come's to readings.
evo10fanatic33
Cobb AccessPORT
Nov 19, 2014 10:06 AM
BoosterX
Nov 8, 2012 04:39 PM
meltdown
May 1, 2010 06:58 PM
Turbotoyzz
Feb 6, 2007 07:43 PM
BigLEVO
Mar 13, 2005 07:15 AM
Quick Reply: Cobb AP different #'s than AEM gauge
