Overboost/Loss of Power/Car emitting Smell
Old Jun 17, 2015, 06:00 PM
t_rally's Avatar
Here is what I have:
2008 Gsr
AMS Intake
GFB BOV
TOPSPEED pro1 CB Exhaust
Cobb Accessport
My car has been performing flawlessly for month up until a couple days ago. It has started over boosting up to 30 psi when I had it consistently in the 24s with the stage 1 lwg tune. It also losses acceleration in the high psi range when it should be peaking acceleration. It also started emitting a slight odor. Could this be a boost leaking? The car performs and runs perfect when driven conservative. It idles smooth and no engine lights. I also checked accessport for codes and it shows none. Any thoughts?
Old Jun 17, 2015, 06:41 PM
kaj
kaj's Avatar
it's probably loosing power at 30psi because it's running dangerously lean. like "burn a hole in the piston" lean. it could be also seeing knock then pulling timing, etc.
all bad. do NOT let it go above the boost you are tuned!
Old Jun 18, 2015, 05:02 AM
t_rally's Avatar
That would make sense. My mechanic added a gas treatment in the gas tank when he changed my oil. Do I just simply just need to burn threw this tank of gas and it will be ok or do I need to change my oil too?
Old Jun 18, 2015, 06:57 AM
rico05's Avatar
"Gas treatment" won't increase boost, but never put that snake oil into your car regardless.
Check the lines to your EBC. Other than that, try reflashing the map onto the car.
Old Jun 18, 2015, 07:57 AM
t_rally's Avatar
Thanks for the reply, I'm taking it to my mechanic at lunch today and do a compression test and check the EBC. I have reflashed it to stage0 and even back to the stock flash and it is this spiking to 28ish psi.
i'll follow up after check.
Old Jun 18, 2015, 08:27 AM
rongdoer's Avatar
Does the ams filter get oiled? If so, clean your maf sensor.
Old Jun 18, 2015, 12:27 PM
t_rally's Avatar
hmm it does have some black stuff on the filter, I just though it was a little dirty, they suspect getting new MAF sensor too, ill see if they can just clean it!!!
Old Jun 18, 2015, 01:45 PM
kaj
kaj's Avatar
Your boost controller should be the source of over boosting.
A quick test would be to bypass it then make a quick run.
Old Jun 26, 2015, 03:05 PM
bunnishiwa's Avatar
Hi,
Guy here in Oz had similar over boosting issues and on advice from his tuner went back to stock BOV and they went away. An easy thing to swap and check. Could also be lines in/out of the 3 port but unlikely. That being said have you done a boost leak test? If you've access to a compressor the partsyou need cost less than $10 from Home Depot or similar - just Google 'boost leak test evo x'
Old Jun 27, 2015, 09:32 AM
t_rally's Avatar
Guess I got my car back and it was the MAF sensor. It is now boosting to 24ish psi and then tapering off. If I have anymore issues I will post back here but for now it is resolved.
Old Jun 27, 2015, 11:40 AM
kaj
kaj's Avatar
The MAF caused an overboost condition? I gotta look that one up.
Old Jul 1, 2015, 09:06 PM
MrJoshH's Avatar
In first gear my RPMs shoot to 6 with almost no power. Not sure if that's the same issue you were having as well.
Old Jul 2, 2015, 10:50 AM
t_rally's Avatar
Sorry I missed understood the tech he said it was the boost pressure sensor. That sounds more about right yes?
Old Jul 2, 2015, 01:15 PM
kaj
kaj's Avatar
if it failed to control, boost, then yes. if it was bleeding off too much, the WG wouldn't ever see it's target boost it would stay shut. then your motor goes boom. good thing you caught it sooner than later.
Old Jul 10, 2015, 09:14 AM
t_rally's Avatar
yea thankfully! It's still running strong now. We can put this one to rest.
EVOXMAINE
Jun 4, 2009 05:57 PM
Johnboy1065
12
Jan 28, 2008 01:38 PM
use2vtec
16
Jan 19, 2008 11:45 PM
ecmotorsports
Sep 29, 2005 11:12 AM
hkfeet
Sep 2, 2005 09:05 PM
Quick Reply: Overboost/Loss of Power/Car emitting Smell
