Evo X flex fuel tuning on Accessport
So I called delicious tuning after reading about this in the Nov. D-sport magazine.
It has dynamic temperature compensation, so it's really safe and adaptable to different air temps.
It's completely plug and play, interfacing with all the factory connectors and fuel lines, taking less than 30 mins to install.
I think this is the kit i'm going with, as it's the only complete kit on the market that doesn't seem like a hodgepodge of stuff. Also, saw on instagram Dr.Boost is tuning these kits now, it's really an exciting time!LOL
http://flexconverter.com/collections...x-fuel-package
Takes 20 mins tops to install and it's $200 less then what you are looking at.
flexconverter.com makes a fully plug and play kit that isn't a "hodgepodge of stuff":
Do you know how long it takes to jack up really low cars?
With the Delicious kit, you don't have to jack up anything, it's all done under the hood.
Also does that work with Cobb? I don't see any mention of that.
20 minutes? According to the instructions on their website looks like you need to monkey around with the fuel tank and jack up the the car to run things underneath the car.
Good luck!
shekaar (Mar 23, 2016)
I just thought it was funny you said 20 minutes tops, taking the seat out, accessing the fuel tank, installing the kit, jacking up the car doing wiring underneath, tidying up said wires so nothing get's snagged under the car etc. Some people can't even change a tire in under 20 minutes.
20 minutes is if you take your time, the flex converter kit is so simple a toddler can install it. How long to jack up a lowered car.. drive up on a 2x4 and then jack the side of your car up... its really that simple.
And patch on a patch, that's funny. I've run tephra's ROM's on my X since they came out and was one of the first supporters of V2 and V3 and if it wasn't for his work many things on the X would not be possible as they are today. I'd rather have tested/proven code control the flex configuration seamlessly vs any type of trickery and save the money to put toward something else but to each there own...
What do you mean software trickery? You do know that Cobb, Ecutek and Ecuflash all do the same thing when it comes to making a new feature, correct?
They all reprogram the ROM file to do what they want, all deviations from the factory code, and flash it back to the ECU.
So with your logic, they all do software trickery.
Did anyone break this down?
Is the delicious tuning like an old school Apexi AFC, intercepting and mangling parameters like the MAF reported HZ (only based on ethanol content)?
Does anyone know exactly how the delicious tuning solution works?
flex converter kit just reads the ethanol content. That is a fraction of the entire problem.
~Jaraxle
~Jaraxle
I got the kit yesterday! Actually took 10 minutes to install, looks really clean. Flashed the AP with Delicious tune, it effing works! One thing I like is I have the Accessport that I can monitor my ethanol percentage, as well as other things. OS you need to carry a laptop everywhere or connect your phone to just view e content.
This is so frick'n awesome! Now I won't be one of those guys at the e85 pump waiting for my car die to get all the 91 octane out. LOL
Ok so how does the ethanol content sensor get the % of ethanol to the ECU/tune?
Does the tune have to be an OTS Cobb tune (aka: pretty much stock car) ?
Does it interpolate injector scaling, boost, timing, etc throughout the range for ethanol %?
~Jaraxle
