P0133 code /stalling/ rough and lean idle
Hello i have a evo x with dw1000cc injectors and ETS turbo kit with 250cc fuel pump and tuned by JMS on Cobb AP. I recently moved to hawaii and ever since i got my car back from shipping its hard to start/stalls. it did it when i lived in texas but on rare occasion. When the car doesnt start on the first time i smell fuel. Also for some weird reason when my radiator fans cut on or when car comes under load it either acts normal,bogs down (almost stalls) or it does stall. my Idles lean but its fine when driving. i unplugged the MAF while i was parked one time to see if it would stall or get worse, but to my surprise it idled exactly where it was suppose to,not running lean at all. today i started the car and the engine flooded at intial start, i had to unplugg the injectors and start it to get the fuel out. the car started and i saw white smoke come from engine bay and smelled fuel ,some even came out under the driver side door i had open, it wasnt alot but enough for me to notice.
I have an 08 GSR and the same exact problem. I have 1000cc FIC injectors, aftermarket air intake and a Tephra Tune. The fans come on and off all the time and when i come to a stop it leans out, bogs down and either stalls or wants to stall. I replaced my front O2 sensor today and still have the same problem/code. From what I've dug up, this code and these symptoms can be caused my an exhaust leak/after market intake. Hopefully someone out there knows whats going on!
89turbosupra
Feb 12, 2016 06:03 PM
