Look at my data log, is anything wrong?
Old Jan 8, 2017, 10:11 PM
dk3Jdefje1X's Avatar
This is a wot run, I'm on stock turbo, stock block. Full bolt ons besides down pipe and fuel system (if that counts). My reason for posting is that I feel like I'm over boosting, this pull says 28 pounds, but when my tires spin I hit 30, but only when my tires spin which is rarely (only when wet). My injectors is my biggest count concern because usually at wot I hit in the upper 90% and rarely 100%, and today I saw it hit 110% for the first time. I usually don't beat on the car and I occasionally do wot pulls. I'm not going to upgrade my turbo, I make 301whp. Retune? New injectors? Help!
Old Jan 8, 2017, 10:23 PM
4b11slayer's Avatar
Too much injector duty cycle.
What pump?
Old Jan 8, 2017, 10:33 PM
What pump?
Stock pump and injectors
Old Jan 9, 2017, 07:36 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by JacksonEvoX
I usually don't beat on the car and I occasionally do wot pulls....
...but when I do, I go 144mph.
Old Jan 9, 2017, 09:35 AM
4b11slayer's Avatar
^^ lol.
Well im pretty sure youve maxed out your injectors. Might be able to drop some cycle by putting a pump in it, but injectors and pump should be upgraded.
Old Jan 9, 2017, 10:04 AM
RazorLab's Avatar
^^ lol.
the oem evo 10 pump will support anything the stock turbo can dish out on pump gas, easily.
Old Jan 9, 2017, 10:27 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
What fuel are you running? 28-30psi seems like a lot of boost unless you have really good pump gas in your area.
Old Jan 9, 2017, 04:48 PM
93 pump gas. Stock turbo
Old Jan 9, 2017, 04:49 PM
yeah, that's what I heard. Just minor bolt ons and tune is all I have. No injectors or fuel pump
Old Jan 9, 2017, 05:21 PM
4b11slayer's Avatar
That's a lot of boost for stock injectors no?
Old Jan 20, 2017, 03:46 AM
GP148's Avatar
Taper down your peak boost to something like 25. Save your rods. Plenty safe with 25 otherwise as long as your tune is good
Old Jan 21, 2017, 10:41 AM
spoolin turbo's Avatar
Time to upgrade.
Or lower boost
Old Feb 16, 2017, 08:08 AM
ddlopresti's Avatar
is this using a Cobb AP tune? If so, get a pro tune and problems will likely be solved.
Old Feb 21, 2017, 12:23 PM
Your stock pump may be going out. Replace it with an Asnu drop in pump and go from there.
I'm still concerned with the amount of boost. Its running quite a bit.
Old Mar 13, 2017, 02:10 PM
ddlopresti's Avatar
got a pro tune, paid $550. Tuned by @JrTuned from shift fast motorsports in rock hill South Carolina. Suppose to be a perfect tune
I'm my experience, no matter the tuner, there is no perfect tune. I always log after being tuned and usually have my tuner make small revisions. The way a dyno loads up the motor is different than real world conditions, not to mention seasonal changes. I'd suggest doing a proper log and having your tuner check it and make some revisions. Seems like it's being pushed harder than the mods you have can support safely.
uSmC_08
Oct 2, 2007 06:30 PM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
Quick Reply: Look at my data log, is anything wrong?
