7.2whp gains by adding Royal Purple oil
First of all, moderators, please feel free to remove my topic if it has been covered/adressed before.
With that being said I ran into a dyno test done in a Evo X, the test consisted on adding some simple bolt ons like a panel filter, exhaust and changing oil to Royal Purple.
If you ask me, I have always been a firm believer of good synthetic oils, back from when I attended mechanical vocational school in late 80s I always learned of the benefits of the synthetic oil. It is not optional for me to do a oil change with something other than synthetic oil, they are not just worth the money but far worth in the long run.
A car magazine landed on my hands a few years ago in which one more time a dyno test was done to test transmission fluids, at that time Royal purple squeeze 3 or 4 WHP by providing low friction fluid enhancing the cooling and the friction.
I have seen relatively modern cars which has been regularily maintain by the dealers on a strict regular oil changes, particularily a owner of a Ford Mustang GT had his engine completely seized and oil filter clogged with sludge, is a matter of fact, it looks just like if someone grabbed a 55 galon drum barrel fill of dark industrial grease and applied over the engine as if it was butter.
Here is the link and if you ask me if I believe it I will repeat, yes I do:
http://www.royalpurple.com/drag-sport2.html
Carlos
Carlos
That review neglected that part and an A-B-A test to fully validate it.
That oil could have been abused for the last 3500 miles and was due for a change. I would have like to see they swap back to fresh mobile 1 with the a K&N filter to prove the results.
edit: i missed the part where it said 350 mi on the car so witht eh exectption of the filter providing power it is reasonable to assume it was the oil.
^^^ This is a little misconception. The engine is making xxxx power, the fluids within will enhance the output by reducing friction and cooling it and "freeing it".
There is an article rarely seen from a huge laboratory test which in that specific test all they did was bearings. The test consisted on a spinning bearing and a hydraulic arm pressing on the bearing with enormous pressure. The pictures showed most of the other oils causing groves on the bearings.
I attempted to download that same link from work like 3 years ago but my work had filters. I then tried copy and pasting the info but again it got blocked. I am sure I could find the info again. I surf thorugh many car forums every day, I am sure I could provide the link .
When it comes to lab test, you can't argue that, that is the real deal.
http://www.animegame.com/cars/Oil%20Tests.pdf
Carlos
Carlos
You worried about oil sludge in an evo, that's rich. Maybe a camary but I doubt you'll have many issues with sludge with mobil 1 synthetic. RP has these graphite like particles in the oil, and with extended use I believe RP will cause some issues. I've used it once on my old IS300 the results were good, but the oil doesn't last very long. Personally I'd stick with the OEM after this go around with RP, but that's just my two cents.
I believe that it MAY have had a 1-2hp increase, but we all know the same car, without changing it in anyway, from one run to the next, can show a difference of 5whp.
On GST's mustang dyno, my car made between 260whp to 266whp between 3 pulls. Runs were only about 1 minute apart and we made no changes to the car. If anything the dyno room got warmer.
I use amsoil in everything, and I do believe it is partially the reason why I had better than average numbers on an untuned VIII with minimal mods.
Acoording to this real test, Mobil one perfromed poorly:
Carlos
Carlos
Carlos
I am sure the Mobil one oil also brings benefits to the table. There is an article rarely seen from a huge laboratory test which in that specific test all they did was bearings. Amsoil absolutely swept the competition. While all the bearings seized up Amsoil lasted several times more than the others.
The bearing was tested in a bench. The test consisted on a spinning bearing and a hydraulic arm pressing on the bearing with enormous pressure. The pictures showed most of the other oils causing groves on the bearings while AMSOIL provided silky smooth friction.
Carlos
Carlos
Carlos
Carlos
good article thanks!
If you liked that read, you'll like this:
http://www.sfrcorp.com/demonstration/
Gee...I wonder what brand oil they are testing against...
Mobile 1 is a great oil, but for those thoroughly concerned with their oil, buy amsoil or use SFR additive to your mobile 1. Like I said, I have not researched Royal Purple well, it may be an excellent alternative as well.
BTW, GM uses SFR on their assembly lines to lubricate the rollers and bearings.
